mindwave
I know there is a simpl answer - USB HD Question
Wed Jul 08, 2020 9:53 pm
Team
Ok, I have a raspi4 2GB runnning the 05/27 RASPI-OS nothing really thrilling.
I was working on getting all my files organized and setup the way I wanted, you know my mp3s on one drive videos on another etc.
Than I did that ting that will kill any well planned project - I moved.
And the pros I paid to move my stuff were very careful, but not very organized, so I have taken MONTHS to locate things that should have been within reach from day 1, and of course labels were ignored.
SO i start to get everything put in its place and all my mp3s are on one drive and KODId away!
Now for my videos, well those were on several drives, the lables of which were not maintained so i plug them in and see whats on there. UNFORTUNATELY, my setup isnt exactly as it was. For example I didnt have this many RASPI4s when I started so there were a bunch of customizes 3's linked up, but thats not to be at the moment.
I believe I have unboxed the majority of my USB Hard Drives, BUT I am encountering a big issue. MANY of the plug in fire up and immediately generate a mount error.
so I break out my copy of gparted and seee my 3TB deive listed with a bang on 2 partitions:
PARTITION NAME FILE SYSTEM LABEL SIZE FLAGS
/dev/sda1 Microsoft reserved partition unknown 128MB msftres
/dev/sda2 Basic Data partition ntfs Seagate Expansion Drive 2.73TB msftdata
Now, a few things: 1) My prmary PC for 15 years has been a linux mint desktop, with various laptops of some windows some Mint installs
2) In most cases these drives were all plug and play
3) many were on my Mint desktop at one point or another, a FEW of them ay have been used on a Win7/10 laptop for short
periods of time.
4) This is the big one. I have a genetic disorder that forhe last several years has TRASHED my short term memory
I add that last because as some of you may try and help or offer suggestions I may not have information that is blatently obvious to most folks.
Just for grins, I have plugged some of these externals into a win10 PC just to see if THEY could be read, and they are not even recognized as being plugged in?
I have probably 30TB of data amongst these drives, so any valid ideas are REALLY welcomed.
J
topguy
Re: I know there is a simpl answer - USB HD Question
Thu Jul 09, 2020 10:21 am
But what is that error ?
Kernel/system messages available with the "dmesg" command after you plug in the drive could also be useful.
mindwave
Thu Jul 09, 2020 12:22 pm
sorry dont have a screen shotter installed yet:
error on plugin:
Error mounting /dev/sda2 at media/pi/Seagate Expansion Drive: Unknown error when mounting /dev/sda2
dmesg was a great idea, its kind of long......
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 5.4.42-v8+ (dom@buildbot) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9)) #1319 SMP PREEMPT Wed May 20 14:18:56 BST 2020
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 2048000
[ 0.000000] DMA zone: 3584 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 229376 pages, LIFO batch:63
[ 0.000000] DMA32 zone: 12288 pages used for memmap
[ 0.000000] DMA32 zone: 770048 pages, LIFO batch:63
[ 0.000000] Normal zone: 16384 pages used for memmap
[ 0.000000] Normal zone: 1048576 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 31 pages/cpu s89240 r8192 d29544 u126976
[ 0.000000] pcpu-alloc: s89240 r8192 d29544 u126976 alloc=31*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] ARM_SMCCC_ARCH_WORKAROUND_1 missing from firmware
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2015744
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 video=HDMI-A-1:640x480M@60 smsc95xx.macaddr=DC:A6:32:B1:BD:5B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=6d480980-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x34000000-0x38000000] (64MB)
[ 0.000000] Memory: 7687420K/8192000K available (9532K kernel code, 1102K rwdata, 3340K rodata, 1088K init, 1199K bss, 242436K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 31644 entries in 124 pages
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4c4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000211] Console: colour dummy device 80x25
[ 0.000235] printk: console [tty1] enabled
[ 0.000284] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[ 0.000300] pid_max: default: 32768 minimum: 301
[ 0.000635] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.000709] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001719] Disabling memory control group subsystem
[ 0.024043] ASID allocator initialised with 32768 entries
[ 0.032037] rcu: Hierarchical SRCU implementation.
[ 0.040387] EFI services will not be available.
[ 0.048097] smp: Bringing up secondary CPUs ...
[ 0.080292] Detected PIPT I-cache on CPU1
[ 0.080351] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.112394] Detected PIPT I-cache on CPU2
[ 0.112435] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.144508] Detected PIPT I-cache on CPU3
[ 0.144548] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.144689] smp: Brought up 1 node, 4 CPUs
[ 0.144700] SMP: Total of 4 processors activated.
[ 0.144711] CPU features: detected: 32-bit EL0 Support
[ 0.144722] CPU features: detected: CRC32 instructions
[ 0.167993] CPU: All CPU(s) started at EL2
[ 0.168043] alternatives: patching kernel code
[ 0.169928] devtmpfs: initialized
[ 0.179330] Enabled cp15_barrier support
[ 0.179358] Enabled setend support
[ 0.179764] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.179788] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.186635] pinctrl core: initialized pinctrl subsystem
[ 0.187304] DMI not present or invalid.
[ 0.187636] NET: Registered protocol family 16
[ 0.190384] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.191079] cpuidle: using governor menu
[ 0.191465] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.191684] Serial: AMBA PL011 UART driver
[ 0.194801] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.208705] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-06-01 13:24, variant start_x
[ 0.212716] raspberrypi-firmware soc:firmware: Firmware hash is 6379679d1ec6a8c746d7e77e015f5b56b939976f
[ 0.257765] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.260810] vgaarb: loaded
[ 0.261299] SCSI subsystem initialized
[ 0.261498] usbcore: registered new interface driver usbfs
[ 0.261548] usbcore: registered new interface driver hub
[ 0.261647] usbcore: registered new device driver usb
[ 0.263003] clocksource: Switched to clocksource arch_sys_counter
[ 0.958611] VFS: Disk quotas dquot_6.6.0
[ 0.958694] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.958875] FS-Cache: Loaded
[ 0.959107] CacheFiles: Loaded
[ 0.959899] simple-framebuffer 3ea9b000.framebuffer: framebuffer at 0x3ea9b000, 0x12c000 bytes, mapped to 0x(____ptrval____)
[ 0.959915] simple-framebuffer 3ea9b000.framebuffer: format=a8r8g8b8, mode=640x480x32, linelength=2560
[ 0.960308] Console: switching to colour frame buffer device 80x30
[ 0.961982] simple-framebuffer 3ea9b000.framebuffer: fb0: simplefb registered!
[ 0.971182] thermal_sys: Registered thermal governor 'step_wise'
[ 0.971494] NET: Registered protocol family 2
[ 0.972198] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.972262] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.972672] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.973491] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.973728] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.973822] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.974180] NET: Registered protocol family 1
[ 0.975100] RPC: Registered named UNIX socket transport module.
[ 0.975110] RPC: Registered udp transport module.
[ 0.975118] RPC: Registered tcp transport module.
[ 0.975127] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.975145] PCI: CLS 0 bytes, default 64
[ 0.977031] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.977261] kvm: Limiting the IPA size due to kernel Virtual Address limit
[ 0.977270] kvm [1]: IPA Size Limit: 43bits
[ 0.978031] kvm [1]: vgic interrupt IRQ1
[ 0.978260] kvm [1]: Hyp mode initialized successfully
[ 0.980205] Initialise system trusted keyrings
[ 0.980465] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 0.988943] FS-Cache: Netfs 'nfs' registered for caching
[ 0.989590] NFS: Registering the id_resolver key type
[ 0.989618] Key type id_resolver registered
[ 0.989627] Key type id_legacy registered
[ 0.989646] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.990763] Key type asymmetric registered
[ 0.990774] Asymmetric key parser 'x509' registered
[ 0.990816] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.991095] io scheduler mq-deadline registered
[ 0.991105] io scheduler kyber registered
[ 0.994242] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.994262] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 0.994319] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
[ 0.994374] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
[ 1.057100] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
[ 1.057399] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.057414] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.057430] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 1.057480] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.057695] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.061000] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.061190] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.061260] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.061468] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.064628] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.064664] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.064683] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.064716] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.064735] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.064813] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.064839] pci 0000:01:00.0: enabling device (0000 -> 0002)
[ 1.120158] pci 0000:01:00.0: quirk_usb_early_handoff+0x0/0x900 took 54038 usecs
[ 1.122275] raspberrypi-clk firmware-clocks: CPU frequency range: min 600000000, max 1500000000
[ 1.124217] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 1.126379] iproc-rng200 fe104000.rng: hwrng registered
[ 1.126716] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.127490] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.127845] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.137602] brd: module loaded
[ 1.149012] loop: module loaded
[ 1.150225] Loading iSCSI transport class v2.0-870.
[ 1.152025] libphy: Fixed MDIO Bus: probed
[ 1.152539] bcmgenet fd580000.ethernet: failed to get enet clock
[ 1.152556] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.152574] bcmgenet fd580000.ethernet: failed to get enet-wol clock
[ 1.152590] bcmgenet fd580000.ethernet: failed to get enet-eee clock
[ 1.152612] bcmgenet: Skipping UMAC reset
[ 1.163078] libphy: bcmgenet MII bus: probed
[ 1.215101] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.215991] usbcore: registered new interface driver r8152
[ 1.216057] usbcore: registered new interface driver lan78xx
[ 1.216105] usbcore: registered new interface driver smsc95xx
[ 1.216568] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.216595] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.217386] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 1.218599] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 1.218613] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.218625] usb usb1: Product: xHCI Host Controller
[ 1.218637] usb usb1: Manufacturer: Linux 5.4.42-v8+ xhci-hcd
[ 1.218648] usb usb1: SerialNumber: 0000:01:00.0
[ 1.219253] hub 1-0:1.0: USB hub found
[ 1.219338] hub 1-0:1.0: 1 port detected
[ 1.219832] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.219851] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.219871] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.220263] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ 1.220276] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.220288] usb usb2: Product: xHCI Host Controller
[ 1.220300] usb usb2: Manufacturer: Linux 5.4.42-v8+ xhci-hcd
[ 1.220310] usb usb2: SerialNumber: 0000:01:00.0
[ 1.220819] hub 2-0:1.0: USB hub found
[ 1.220877] hub 2-0:1.0: 4 ports detected
[ 1.222078] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.222313] dwc_otg: FIQ enabled
[ 1.222322] dwc_otg: NAK holdoff enabled
[ 1.222330] dwc_otg: FIQ split-transaction FSM enabled
[ 1.222341] Module dwc_common_port init
[ 1.222825] usbcore: registered new interface driver uas
[ 1.222915] usbcore: registered new interface driver usb-storage
[ 1.223132] mousedev: PS/2 mouse device common for all mice
[ 1.224787] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.226965] sdhci: Secure Digital Host Controller Interface driver
[ 1.226975] sdhci: Copyright(c) Pierre Ossman
[ 1.227516] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.227984] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.231308] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.231464] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.231603] usbcore: registered new interface driver usbhid
[ 1.231612] usbhid: USB HID core driver
[ 1.232780] vchiq: vchiq_init_state: slot_zero = (____ptrval____)
[ 1.236282] Initializing XFRM netlink socket
[ 1.236317] NET: Registered protocol family 17
[ 1.236427] Key type dns_resolver registered
[ 1.237065] registered taskstats version 1
[ 1.237084] Loading compiled-in X.509 certificates
[ 1.237333] Key type ._fscrypt registered
[ 1.237342] Key type .fscrypt registered
[ 1.248694] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.248770] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 14, base_baud = 0) is a PL011 rev2
[ 1.255990] printk: console [ttyS0] disabled
[ 1.256053] fe215040.serial: ttyS0 at MMIO 0x0 (irq = 16, base_baud = 62500000) is a 16550
[ 1.256111] printk: console [ttyS0] enabled
[ 1.256602] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.257305] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 1.258095] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.258107] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.302767] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.304399] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.306026] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.308948] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.310575] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.323927] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.326436] of_cfs_init
[ 1.326557] of_cfs_init: OK
[ 1.327798] Waiting for root device PARTUUID=6d480980-02...
[ 1.349706] random: fast init done
[ 1.370801] mmc1: new high speed SDIO card at address 0001
[ 1.428794] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
[ 1.429660] mmcblk0: mmc0:aaaa SN128 119 GiB
[ 1.436279] mmcblk0: p1 p2
[ 1.454776] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.454849] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.455788] devtmpfs: mounted
[ 1.459096] Freeing unused kernel memory: 1088K
[ 1.467104] Run /sbin/init as init process
[ 1.555473] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 1.580499] usb 2-2: New USB device found, idVendor=0bc2, idProduct=3323, bcdDevice= 1.00
[ 1.580514] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 1.580527] usb 2-2: Product: Expansion+ Desk
[ 1.580538] usb 2-2: Manufacturer: Seagate
[ 1.580549] usb 2-2: SerialNumber: NA8B0WT5
[ 1.593040] scsi host0: uas
[ 1.594376] scsi 0:0:0:0: Direct-Access Seagate Expansion+ Desk 9401 PQ: 0 ANSI: 6
[ 1.595931] sd 0:0:0:0: [sda] 5860533167 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 1.605651] sd 0:0:0:0: [sda] Write Protect is off
[ 1.605666] sd 0:0:0:0: [sda] Mode Sense: 4f 00 00 00
[ 1.605983] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.606664] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 1.686786] sda: sda1 sda2
[ 1.689653] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.707065] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.856890] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.856907] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.856919] usb 1-1: Product: USB2.0 Hub
[ 1.858378] hub 1-1:1.0: USB hub found
[ 1.858622] hub 1-1:1.0: 4 ports detected
[ 1.880487] systemd[1]: System time before build time, advancing clock.
[ 1.981374] NET: Registered protocol family 10
[ 1.982769] Segment Routing with IPv6
[ 2.023872] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.024521] systemd[1]: Detected architecture arm64.
[ 2.052256] systemd[1]: Set hostname to <raspberrypidesktop>.
[ 2.151082] usb 1-1.1: new low-speed USB device number 3 using xhci_hcd
[ 2.259848] usb 1-1.1: New USB device found, idVendor=1d57, idProduct=0005, bcdDevice= 1.00
[ 2.259865] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.259878] usb 1-1.1: Product: HID-compliant Mouse
[ 2.259889] usb 1-1.1: Manufacturer: HID-compliant Mouse
[ 2.269527] input: HID-compliant Mouse HID-compliant Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:1D57:0005.0001/input/input0
[ 2.269894] hid-generic 0003:1D57:0005.0001: input,hidraw0: USB HID v1.10 Mouse [HID-compliant Mouse HID-compliant Mouse] on usb-0000:01:00.0-1.1/input0
[ 2.351054] usb 1-1.3: new low-speed USB device number 4 using xhci_hcd
[ 2.458871] usb 1-1.3: New USB device found, idVendor=0e8f, idProduct=0022, bcdDevice= 2.10
[ 2.458887] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.458899] usb 1-1.3: Product: USB KB V11
[ 2.458911] usb 1-1.3: Manufacturer: GASIA
[ 2.468090] input: GASIA USB KB V11 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:0E8F:0022.0002/input/input1
[ 2.527628] hid-generic 0003:0E8F:0022.0002: input,hidraw1: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-0000:01:00.0-1.3/input0
[ 2.537603] input: GASIA USB KB V11 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:0E8F:0022.0003/input/input2
[ 2.595253] input: GASIA USB KB V11 System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:0E8F:0022.0003/input/input3
[ 2.595434] hid-generic 0003:0E8F:0022.0003: input,hidraw2: USB HID v1.10 Device [GASIA USB KB V11] on usb-0000:01:00.0-1.3/input1
[ 2.602566] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.608734] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.609275] systemd[1]: Listening on udev Kernel Socket.
[ 2.609648] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.609973] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.610502] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.611626] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.612263] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.612647] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.612755] systemd[1]: Reached target Swap.
[ 2.679080] usb 1-1.4: new high-speed USB device number 5 using xhci_hcd
[ 2.757542] i2c /dev entries driver
[ 2.780307] usb 1-1.4: New USB device found, idVendor=1058, idProduct=1021, bcdDevice=20.21
[ 2.780324] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.780337] usb 1-1.4: Product: Ext HDD 1021
[ 2.780349] usb 1-1.4: Manufacturer: Western Digital
[ 2.780360] usb 1-1.4: SerialNumber: 5743415A4148393039363834
[ 2.782739] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[ 2.807504] scsi host1: usb-storage 1-1.4:1.0
[ 3.372211] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.425486] systemd-journald[141]: Received request to flush runtime journal from PID 1
[ 3.437190] systemd-journald[141]: File /var/log/journal/66f966c908a54ea7a2c813a2389aa0f1/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 3.846147] scsi 1:0:0:0: Direct-Access WD Ext HDD 1021 2021 PQ: 0 ANSI: 4
[ 3.850881] sd 1:0:0:0: [sdb] 3907024896 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 3.853552] sd 1:0:0:0: [sdb] Write Protect is off
[ 3.853572] sd 1:0:0:0: [sdb] Mode Sense: 17 00 10 08
[ 3.859207] sd 1:0:0:0: [sdb] No Caching mode page found
[ 3.859226] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[ 3.903480] sdb: sdb1
[ 3.911255] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 4.123734] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.124349] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.125055] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.125844] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.149958] mc: Linux media interface: v0.10
[ 4.179138] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.181493] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.181511] [vc_sm_connected_init]: start
[ 4.216252] [vc_sm_connected_init]: installed successfully
[ 4.223808] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.262295] videodev: Linux video capture interface: v2.00
[ 4.331469] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 4.356634] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.357366] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.359303] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.367258] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.377615] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 4.414167] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.426306] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.595119] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 4.595177] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.604005] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 4.604027] checking generic (3ea9b000 12c000) vs hw (0 ffffffffffffffff)
[ 4.604038] fb0: switching to vc4drmfb from simple
[ 4.604415] Console: switching to colour dummy device 80x25
[ 4.604605] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.604615] [drm] No driver support for vblank timestamp query.
[ 4.604623] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 4.605182] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 4.607340] vc4-drm gpu: HDMI-A-1: EDID is invalid:
[ 4.607360] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.607369] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.607378] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.607387] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.607395] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.607404] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.607413] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.607421] [00] ZERO 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 4.609330] Console: switching to colour frame buffer device 80x30
[ 4.609371] vc4-drm gpu: fb0: vc4drmfb frame buffer device
[ 4.721073] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.811557] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 4.818372] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 4.842175] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.853590] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.854730] usbcore: registered new interface driver brcmfmac
[ 4.876241] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 5.006409] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 5.006883] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 5.007308] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 5.007596] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 5.007622] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 5.007639] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 5.007654] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 5.007680] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 5.007876] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 5.009309] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 5.009356] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 5.018538] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 5.018585] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 5.026977] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 5.027056] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 5.095639] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.110065] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
[ 5.280107] random: crng init done
[ 5.280122] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.927522] uart-pl011 fe201000.serial: no DMA platform data
[ 7.105095] 8021q: 802.1Q VLAN Support v1.8
[ 7.508050] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 7.561735] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 7.921945] bcmgenet: Skipping UMAC reset
[ 7.926727] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 7.927111] bcmgenet fd580000.ethernet eth0: Link is Down
[ 9.724430] broken atomic modeset userspace detected, disabling atomic
[ 12.684341] fuse: init (API version 7.31)
[ 13.596169] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 13.885605] Bluetooth: Core ver 2.22
[ 13.885661] NET: Registered protocol family 31
[ 13.885665] Bluetooth: HCI device and connection manager initialized
[ 13.885679] Bluetooth: HCI socket layer initialized
[ 13.885686] Bluetooth: L2CAP socket layer initialized
[ 13.885698] Bluetooth: SCO socket layer initialized
[ 13.903545] Bluetooth: HCI UART driver ver 2.3
[ 13.903557] Bluetooth: HCI UART protocol H4 registered
[ 13.903600] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.903803] Bluetooth: HCI UART protocol Broadcom registered
[ 14.088745] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.088754] Bluetooth: BNEP filters: protocol multicast
[ 14.088767] Bluetooth: BNEP socket layer initialized
[ 14.122343] cryptd: max_cpu_qlen set to 1000
[ 14.127953] Bluetooth: RFCOMM TTY layer initialized
[ 14.127975] Bluetooth: RFCOMM socket layer initialized
[ 14.127993] Bluetooth: RFCOMM ver 1.11
[ 15.023404] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 35.871469] usb 2-2: USB disconnect, device number 2
[ 35.883374] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 36.123063] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
[ 43.479465] usb 2-2: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[ 43.500448] usb 2-2: New USB device found, idVendor=0bc2, idProduct=3323, bcdDevice= 1.00
[ 43.500466] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 43.500478] usb 2-2: Product: Expansion+ Desk
[ 43.500490] usb 2-2: Manufacturer: Seagate
[ 43.500500] usb 2-2: SerialNumber: NA8B0WT5
[ 43.518256] scsi host0: uas
[ 43.521378] scsi 0:0:0:0: Direct-Access Seagate Expansion+ Desk 9401 PQ: 0 ANSI: 6
[ 43.522938] sd 0:0:0:0: [sda] Spinning up disk...
[ 43.523593] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 44.543006] ...........ready
[ 54.783642] sd 0:0:0:0: [sda] 5860533167 512-byte logical blocks: (3.00 TB/2.73 TiB)
[ 54.788062] sd 0:0:0:0: [sda] Write Protect is off
[ 54.788071] sd 0:0:0:0: [sda] Mode Sense: 4f 00 00 00
[ 54.788297] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 54.788826] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
[ 54.871960] sda: sda1 sda2
[ 54.873734] sd 0:0:0:0: [sda] Attached SCSI disk
