jhaiskendenew
Re: Unable to Login Anymore
Tue Aug 05, 2014 9:17 am
Had EXACTLY this problem. Removed the .Xauthority and everything worked as it should. Many thanks.!!!!
jwarrington
Wed Aug 13, 2014 2:10 pm
Thanks so much for the post it worked for me thanks thought I would have to set up new SD card
Alkadia
Thu Aug 28, 2014 9:37 am
Hi
in my case, I just change the ownership of .Xauthority in my home directory because the ssh and the vnc installation change it to root:root.
Alkadia
crazylooser017
Wed Dec 31, 2014 4:55 pm
Hello everyone,
and happies christmas and new year! I got this problem after make executable a script using VNC, so I'm going to take a look in this to know if I can solve my issue -.-. I'll updated as soon as possible :).
Regards!
crazylooser017
Wed Dec 31, 2014 6:15 pm
Hello again!
I tried the change of Xauthority to the backup and change the own to pi, now I get the open box screen. Now I need to start in the normal screen heh :(
NOTE:
wo wow, I went out of open box, and tried the login/password in the white screen and now I have the access to the desktop :).
No sure if I want to use the tightvncserver again.
One question: If I remove the Xauthority.backup file and let the change of owner could I get access to the desktop?
I'm gonna try.
open box.jpg (16.29 KiB) Viewed 4916 times
Anomaly69
Wed Mar 04, 2015 7:15 am
marcolepsy wrote:I just changed the owner of .Xauthority to the 'pi' user, and it booted back into the GUI without a login screen.
I tried that and it booted to a black screen with a mouse cursor. From there I could get a GUI started, but it didn't boot right into it. Was there anything else you did?
dhruvvyas90
Tue May 19, 2015 5:41 pm
I got the same problem. Booted to blank screen. Did you find a way to correct it ?
TaterBot
Tue Jul 21, 2015 3:57 pm
Hi there,
A late entry to this topic, but I ran into this today and found an easy fix.
I followed the classic tutorials to setup vnc, which resulted in a script /etc/init.d/vncboot
the copy/paste from the internet had an entry for :0.
Change this to :1. :0 is the native HDMI display.
all is well now :)
guyman70718
Me too
Mon Aug 03, 2015 3:14 pm
I have the same problem, but i am already at the command line and i dont have ssh or vnc set up.
evildog1
Thu Aug 27, 2015 5:31 pm
(deleted)
Joe Schmoe
Thu Aug 27, 2015 6:32 pm
What is a "white screen" ?
What is a "black screen" ?
evildog1
Fri Aug 28, 2015 5:21 am
(deleted)
dick.heijkoop
Sat Nov 14, 2015 8:06 pm
This thread saved my L... - thanks for sharing!!
Eredien
Fri Jan 22, 2016 9:56 pm
This is so fantastic! Thanks for this solution! I got into this mess by stupidly typing:
sudo startx
in my terminal window and I could *not* figure out how to get out of the session since it had started automatically running the xserver on Startup! But your solution worked well. Thanks!
Raspberry Pi Newbie
Raspberry Pi B
Mac Mini 2008
Windows 10 PC
See Nautilus sculpture at the Mohawk Valley Mini Maker Faire April 16 2016!
http://www.aculei.net/~eredien/nautilus
Sat Jan 23, 2016 9:12 am
Do this
sudo visudo
Find this line
pi ALL=(ALL) NOPASSWD: ALL
change it to
pi ALL=(ALL) PASSWD: ALL
that will train you to stop prefixing every command with sudo.
This is a doctor free zone.
dustinpeng
Sat Feb 13, 2016 6:52 am
login remotely with SSH.
sudo rm ~/.Xauthority
then can login normally
Mehdi zavari
Thu Feb 25, 2016 2:37 am
Use mRemoteNG
Thats a free software for vnc,ssh,rdp....
1.download and install mRemoteNG from this link:http://www.mremoteng.org/download
2.install xrdp with this command
sudo apt-get install xrdp
(You should be connect to internet to download package details by terminal)
3.after installation get ip address by this code
sudo ifconfig
(Try to setup a static ip address to easy for doing)
4.run mRemoteNG and enjoy!!!
(mremoteng help is very useful to read)
bgoode
Raspberry Pi Certified Educator
Tue Mar 08, 2016 3:34 am
Thanks for the xauthority fix from michaelpgc. I had the same exact problem, and had uninstalled tightvncserver - but obviously it was the root access required for this file that was the problem.
raspberryti
Mon Mar 21, 2016 11:16 am
Suggestion given by Eredien
sudo startx
worked with me - now can access my desktop as before - still one problem
am not able to see an external HardDrive used for data storage commected to Rpi by an USB slot - had same problem in the past with first version of Rpi - solved it just typing
apt-get update
- this time it seems to be useless tough - any suggestion for me?
Raspbian Jessie - Raspberrypi 2
rpdom
Mon Mar 21, 2016 12:47 pm
raspberryti wrote:Suggestion given by Eredien
sudo startx
That is a very bad idea. Better to fix the problem than throw a large hammer at it and cause more damage!
raspberryti
Mon Mar 21, 2016 4:56 pm
Thanks for your comment rpdom still how shall fix the problem if none of the other given solution work? SD card re-flashing? Do you have a better solution?
manci
Fri Apr 01, 2016 8:37 pm
I found a solution in another topic. It worked for me.
DrBobPratt wrote:ON this startx problem, I found the following in my case.
.Xauthority was owned by root and group root. Not sure why this happened. I did install TightVNC which seemed to precipitate the problem. Still trying to figure that one out.
anyway, I did the following
sudo chown pi .Xauthority
sudo chgrp pi .Xauthority
startx
voila, LXDE started up just fine.
Bob Pratt, PhD
ntfschr
Mon Jun 13, 2016 11:25 pm
Just ran into this same issue on my raspberry pi 3. It turns out, I had a syntax error in home/pi/.profile. My code worked fine under bash/zsh, but not for plain old sh (which is a subset AFAIK).
The code I wrote:
function foo()
  # code here
Should have been:
foo()
  # code here
Pub Dude
Mon Aug 01, 2016 2:58 pm
Hi moallen I just wanted to say I have got exactly the same problem on my b+, I have left it for hours and it still doesn't work and now I'm going to look at the other replies and wonder why I havnt looked before.
Pub Dude
Mon Aug 01, 2016 3:15 pm
By the way I've noticed that some of you guys have not changed your password, and you have been experiencing problems. My advice is CHANGE YOUR PASSWORD ASAP, for I have changed mine (from raspberry) and have not experienced 95% of the problems some of you have :?
I hope this comes in use
Benj :P :P :P
Ps, if you CAN login again, type username, password, in correct prompts, and then, at the $ type:
sudo passwd
as this will change password!!!!
