Mafyou
RP4 Not booting any OS.
Tue Jun 23, 2020 12:14 am
I formatted ALL images from Raspberry PI Imager v1.3 and it's never booting.
Official image says "resize the root partition", reboot, and loop when GUI show for 1 second.
Others, it's loop booting always.
And Kali's image says "Kernel panic".
What can I do?
epoch1970
Re: RP4 Not booting any OS.
Tue Jun 23, 2020 7:46 am
Try with a different SD card
Mafyou
Tue Jun 23, 2020 9:06 am
I bought a new Samsung EVO 32Go. It's the one recommanded for RP.
Nothing different.
I tried with a Kali Image 32 bits and it shows multi color display without text.
ps: I had to change the start4.elf.
hansotten
Tue Jun 23, 2020 9:16 am
What power supply?
Other SD card?
Other SD card adapter on PC?
And when you have to change the start4.elf it is possible Kali image is not fit for the RPi 4.
http://duinorasp.hansotten.com for Raspberry Pi and Arduino and ESP8266
http://retro.hansotten.nl for retrocomputing with the 6502 cpu
Tue Jun 23, 2020 9:32 am
Nothing different.
Kali support their software:
https://forums.kali.org/
Thinking outside the box is better than burying your head in the sand...
Mafyou
Tue Jun 23, 2020 9:37 am
Kali is one of the other I tried.
RP Basic image loop boot. Ubuntu, same.
Power Supply by a fresh USB C cable powered by an USB Hub. Green LED is ok
And other adapter? I tried with 2 differents SD Card:
- One Scandisk which got broke.
- Samsung which has many way to function properly for I/O operations. But never show the GUI.
Thanks for reply anyway!
B.Goode
Tue Jun 23, 2020 9:38 am
By whom?
pcmanbob
Tue Jun 23, 2020 9:59 am
Care to elaborate on your power supply ?
A powered Hub is unlikely to supply the 3A a pi4B requires, what is the red LED doing as that indicates 5V ok if on and not flashing.
Mafyou
Tue Jun 23, 2020 10:00 am
By whom?
https://www.androidcentral.com/best-sd- ... berry-pi-4
Mafyou
Tue Jun 23, 2020 10:02 am
This USB Hub isn't on a computer but on the supply directly.
Mafyou
And not flashing a bit.
pcmanbob
Tue Jun 23, 2020 10:11 am
A bad power supply is always the first suspect on a boot loop, when not using the official psu, especially at your pi gets part way through the boot process before rebooting, the only other thing I would check is the SD card you are using.
try testing it with H2testW https://h2testw.en.lo4d.com/windows
care to post a link to the psu you are using.
Mafyou
Tue Jun 23, 2020 12:16 pm
Writing: 27.4MByte/s
Verifying: 34.1 MByte/s
For the PSU: https://www.amazon.fr/gp/product/B01N4O ... UTF8&psc=1 OR https://www.amazon.fr/gp/product/B01C3M ... UTF8&psc=1
For HDMI: https://www.amazon.fr/gp/product/B077V7 ... UTF8&psc=1
Hub: https://www.amazon.fr/gp/product/B00OYU ... UTF8&psc=1
pcmanbob
Tue Jun 23, 2020 12:45 pm
Well the hub is just that a hub, its not even powered with its own supply unless you have added one.
So its still top of my list for the cause of your problems
So is the RED LED on ?
Do you see it go out or flash ?
Mafyou
Tue Jun 23, 2020 1:35 pm
RED LED is ON and not flashing.
Mafyou
Tue Jun 23, 2020 1:38 pm
I tried without the HUB: Same results
pcmanbob
Tue Jun 23, 2020 1:49 pm
So if you removed the Hub were are you powering the pi from ?
Mafyou
Tue Jun 23, 2020 1:53 pm
From an USB to "normal french electrical outlet"
epoch1970
Tue Jun 23, 2020 2:24 pm
PSU=alimentation. Le câble a moins d'importance.
Which PSU?
Mafyou
Tue Jun 23, 2020 2:37 pm
Which PSU?
220V 50Hz
pcmanbob
Tue Jun 23, 2020 3:18 pm
Mafyou wrote:
Tue Jun 23, 2020 3:05 pm
Do I need to get this one: https://www.reichelt.de/FR/FR/raspberry ... aspberrypi ?
Yes that is the official raspberry pi psu you cant do any better than that.
Mafyou
Tue Jun 23, 2020 3:37 pm
Ok, I bought it.
I will post here when I receive this item.
I hope that it will work!
Thank you for your time.
Mafyou
Mon Jun 29, 2020 3:07 pm
You were right!
Thank you for this support!!!
