Any help would be appreciated. I'm happy to provide more info - just let me know what commands to run. Thanks in advance!
Symptoms:
- If I boot with the Sony TV connected:
- I see the rainbow screen and the initial kernel messages.
- At the point when the framebuffer gets reset, the screen goes blank and never returns. The machine is unresponsive and I cannot connect via SSH, even after waiting for 15 minutes. I believe this corresponds to the `switching to vc4drmfb from simple` line in `journalctl`.
- Once I unplug the HDMI cable, I can then SSH soon after.
- As long as the cable is unplugged, SSH is responsive.
- If I plug in the HDMI cable again, SSH immediately stops working. I don't get disconnected; just no echo back of types keys.
- Once I unplug the HDMI cable, SSH immediately resumes. All of my typed keys immediately appear.
- If I plug in another TV or monitor after it has started up, it works fine.
- If I boot headless or with a different monitor, everything works fine. It boots up normally.
- However, I get the same issue as above if I unplug the "good" TV/monitor and then plug in the Sony TV: everything immediately freezes and I cannot SSH. Once I disconnect the Sony TV, it's working again.
- If I boot with the Sony TV connected and `dtoverlay=vc4-fkms-v3d` commented out, it boots fine, but then I can't use emulationstation.
- Modifying or removing `hdmi_force_hotplug`, `hdmi_group`, and/or `hdmi_mode` does not help.
- If I boot with Lakka and the Sony TV, I get no video at all. (Other monitor or TV works fine.)
- I can get the Sony TV to work in a limited fashion as follows:
- Boot headless.
- Connect via SSH.
- Run `tvservice -o`.
- Connect the Sony TV.
- Run `tvservice -e "CEA 5 HDMI"`. Screen is still blank (known issue), but the mode changes on the TV. Other modes work, too.
- Run `fbset -depth 16`. Video now works.
- Emulationstation + snes9x works, too. It even successfully changed mode to 640x480.
- However, upon exiting snes9x, it locked up again. Disconnecting the Sony TV fixed it.
- When I SSH'd in and ran `tvservice -s`, it said it was running in 1080p (not 1080i). Perhaps this is helpful for debugging?
- Hardware: Raspberry Pi 4B rev 1.2
- OS: Raspberry Pi OS Lite Buster, fully updated via apt. (Same on Lakka, see below.)
- Kernel: 4.19.118-v7l+
- TV: Sony KDL-40S2010, which only supports 1080i
- HDMI Port: 0 (next to USB-C)
- Power supply: Vilros Pi 4 USB-C Power Supply With Switch [3 Amp]
- /boot/config.txt:
hdmi_force_hotplug=1 hdmi_group=1 hdmi_mode=5 dtparam=audio=on [pi4] dtoverlay=vc4-fkms-v3d max_framebuffers=2 [all] - /boot/cmdline.txt (default)
console=serial0,115200 console=tty1 root=PARTUUID=29feba32-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait - EDID dump:
00ffffffffffff004dd900950101010129100103804628780a0dc9a05747 982712484c20000001010101010101010101010101010101011d8018711c 1620582c2500dfa42100009e8c0ad08a20e02d10103e960030a421000018 000000fc00534f4e592054560a2020202020000000fd003a3e0f2e08000a 202020202020013102031b76478502030406070123090707830100006603 0c00100080011d007251d01e206e285500dfa42100001e8c0aa01451f016 00267c430030a4210000988c0ad08a20e02d10103e9600dfa4210000188c 0aa01451f01600267c4300dfa42100009800000000000000000000000000 00000000000000000000000000000086
