Greenwellington
Using SSD for multiople OS's
Sat Jun 20, 2020 7:07 pm
I am a complete newcomer to Raspberry Pi and having failed to integrate a KingDian SSD to my newly purchased Pi 4,
I am trying to follow the procedure here:
https://jamesachambers.com/raspberry-pi ... sh-drives/
I have reached the point “Change PARTUUID” and suggestion is d34db33f.
In this example the Disc Identifier seems to have been changed from 0x6c586e13 to 0xd34db33f so is that the same as d34db33f?
However, I do not understand how I enter this suggestion.
Do I copy and paste the whole of that script? Or do I sequentially enter the letters in bold, including this hexadecimal and for the latter do I add the Ox?
If I enter:
sudo fdisk /dev/sda
I get:
Welcome to fdisk (util-linux 2.33.1).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Command (m for help):
Re: Using SSD for multiople OS's
Sun Jun 21, 2020 5:32 am
If I enter:
sudo fdisk /dev/sda
I get:
USB MSD is now usable:
viewtopic.php?f=63&t=277413
Thinking outside the box is better than burying your head in the sand...
RonR
Sun Jun 21, 2020 5:41 am
Running Raspbian from USB Devices : Made Easy works well with USB MSD also.
fbe
Re: Using SSD for multiple OS's
Sun Jun 21, 2020 5:49 am
Just enter the letters in bold and hit the "return " key.
But you will not be able to install multiple OS's on your SSD using this guide or the usb-boot program by RonR. AFAIK NOOBS and PINN have an option to select the installation target for the selected OS.
Sun Jun 21, 2020 6:03 am
...also BerryBoot has support for the 4B.
