DarkElvenAngel
Systemd and the daemon
Fri Jun 19, 2020 1:18 am
Hello everyone,
I wrote a daemon that will fork itself but when I try to run it from systemd the demonizing code doesn't run and the daemon will not run correctly.
I don't understand why this is the case I used
Type=forking
in the service but looking at my daemons log it is skipping the demonize function because it already thinks it's forked?
What can I do to correct this?
pfletch101
Re: Systemd and the daemon
Sat Jun 20, 2020 7:47 pm
You can give us a lot more information! The complete unit file would be a good start. However, I would also check that neither the unit file nor the code you are running makes assumptions about where they are running - file references should be absolute.
DarkElvenAngel
Sat Jun 20, 2020 8:41 pm
Okay so I have a daemon I wrote in C and whenever I run it from the CLI it works perfectly, and the daemon forks thus creating the lock PID file. But when I was using the systemd service to launch it the didn't fork and doesn't create the lock PID file. I didn't include a service file because none of them would work. From the very simple to most complex.
I traced the issue to this line in my code
if(getppid() == 1) return;
i = fork();
Since systemd is PID 1 it would return and not fork and finish setup. So I had to change that line to
if(getpid() == 1) return;
It might have been a typo in the example code or just something old that doesn't work anymore, but now the daemon forks and runs properly. So I sorted it out.
Thanks for replying
RamaSpaceShip
Sun Jun 21, 2020 7:06 am
Since your process cannot have pid 1, this line is useless.
DarkElvenAngel
Sun Jun 21, 2020 1:24 pm
That's what I thought, so why does it work? What is a better way to get the process to fork reliable?
RamaSpaceShip
Sun Jun 21, 2020 3:38 pm
Does it stop forking if you remove that line (if(getpid() == 1) return;) ?
DarkElvenAngel
Mon Jun 22, 2020 2:50 pm
No it still works just fine. Since it wasn't documented I was under the impression that line was to prevent the daemon becoming a fork bomb.
So I will just leave it out.
