RichKavanagh
Trouble updating - GPG error? NO_PUBKEY? Err InRelease?
Mon Dec 31, 2012 4:28 pm
Hi everyone :)
I'm new to this whole linux malarkey and I seem to have come across bit of a problem when trying to update my beloved Raspberry Pi.
Currently running:
Linux raspberrypi2 3.2.27+ #160 PREEMPT Mon Sep 17 23:18:42 BST 2012 armv6l GNU/Linux
I ran "sudo raspi-config" and hit the "update" option which reported an error "There was an error running do_update" so in order to perform an update I tried this from the command line:
sudo apt-get update && sudo apt-get upgrade
(which I think is right??)
That then starts fetching things and reading packages and generally looks good until after a few minutes when I get the following error:
Get:1 http://archive.raspberrypi.org wheezy InRelease [7,737 B]
Get:2 http://mirrordirector.raspbian.org wheezy InRelease [12.5 kB]
Err http://archive.raspberrypi.org wheezy InRelease
Err http://mirrordirector.raspbian.org wheezy InRelease
Fetched 2 B in 0s (6 B/s)
Reading package lists... Error!
W: A error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://archive.raspberrypi.org wheezy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
W: A error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://mirrordirector.raspbian.org wheezy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
W: Failed to fetch http://mirrordirector.raspbian.org/rasp ... /InRelease
W: Failed to fetch http://archive.raspberrypi.org/debian/d ... /InRelease
W: Some index files failed to download. They have been ignored, or old ones used instead.
E: Unable to synchronize mmap - msync (5: Input/output error)
E: Failed to truncate file - ftruncate (30: Read-only file system)
E: Problem renaming the file /var/cache/apt/pkgcache.bin.BU01D3 to /var/cache/apt/pkgcache.bin - rename (30: Read-only file system)
E: The package lists or status file could not be parsed or opened.
I'll admit I am at a complete loss as to what this even means, never mind how to fix it :)
Hopefully someone can help?
joan
Re: Trouble updating - GPG error? NO_PUBKEY? Err InRelease?
Mon Dec 31, 2012 6:48 pm
Could you try
sudo apt-get update
by itself?
What does it say?
RichKavanagh
Mon Dec 31, 2012 7:09 pm
Hi there :)
So I did a "sudo apt-get update", alas it also failed.
Fetched 20.2 kB in 0s (75.4 kB/s)
E: Read error - read (21: Is a directory)
E: Problem opening /var/lib/apt/lists/mirrordirector.raspbian.org_raspbian_dists_wheezy_contrib_binary-armhf_Packages
Does that help?? :)
shuckle
Mon Dec 31, 2012 7:19 pm
I got the same error today. I had disk corruption and i was not able to recover from it. Will install again from scratch tomorrow.
Check if your dmesg shows corruption messages.
RichKavanagh
Mon Dec 31, 2012 7:37 pm
Hi :)
I did a 'dmesg' and waded through the output, nothing is jumping out as me as being unusual or anything that might point towards the issue.
I'm glad in a way that it's not just me this is happening to - it eases my panic somewhat :)
Is there an equivalent of the old DOS 'chkdsk' command that I could try, just to rule that out?
joan
Mon Dec 31, 2012 7:56 pm
As a one off try
sudo apt-get --allow-unauthenticated update
RichKavanagh
Mon Dec 31, 2012 9:00 pm
Hi Joan.
I tried what you suggested, slightly different error (well, the end part anyway):
Get:1 http://mirrordirector.raspbian.org wheezy InRelease [12.5 kB]
Get:2 http://archive.raspberrypi.org wheezy InRelease [7,737 B]
Fetched 20.2 kB in 0s (28.2 kB/s)
Not sure if that one helps or not :)
joan
Mon Dec 31, 2012 9:37 pm
I think the problem is with the reposotries. I'd try again tomorrow.
RichKavanagh
Tue Jan 01, 2013 12:15 pm
I'm not so sure now...
I tried a "sudo apt-get update" on my older (rev1) Raspberry Pi and it updates fine:
pi@raspberrypi1 ~ $ sudo apt-get update
Get:2 http://mirrordirector.raspbian.org wheezy/main armhf Packages [7,400 kB]
Hit http://archive.raspberrypi.org wheezy InRelease
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
(etc)
Tried again this morning on my main rev2 Pi and I get the same errors as per my first post:
pi@raspberrypi2 ~ $ sudo apt-get update
I've just looked at the sources.list file and it's identical on both.
Any other suggestions welcomed, thanks everyone :)
RichKavanagh
Tue Jan 01, 2013 12:27 pm
Sort of getting somewhere... Slightly different error now.
I found and used the commands below, but I have no idea what it's actually done, perhaps someone could enlighten me?
sudo apt-get clean
sudo mv /var/lib/apt/lists /tmp
sudo mkdir -p /var/lib/apt/lists/partial
sudo apt-get clean
sudo apt-get update
Which was taken from http://askubuntu.com/questions/131601/h ... tion-error
Now when I issue a "sudo apt-get update", I get the following (you'll notice the "Err" errors are now missing):
Ign http://archive.raspberrypi.org wheezy InRelease
Ign http://mirrordirector.raspbian.org wheezy InRelease
Get:3 http://mirrordirector.raspbian.org wheezy/main armhf Packages [7,400 kB]
Get:4 http://archive.raspberrypi.org wheezy/main armhf Packages [6,414 B]
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Get:5 http://mirrordirector.raspbian.org wheezy/contrib armhf Packages [23.3 kB]
Get:6 http://mirrordirector.raspbian.org wheezy/non-free armhf Packages [47.7 kB ]
Get:7 http://mirrordirector.raspbian.org wheezy/rpi armhf Packages [14 B]
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Fetched 7,497 kB in 56s (132 kB/s)
Reading package lists... Done
W: GPG error: http://archive.raspberrypi.org wheezy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
W: GPG error: http://mirrordirector.raspbian.org wheezy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9165938D90FDDD2E
So it's just the "NO_PUBKEY" issue to resolve I think...
RichKavanagh
Tue Jan 01, 2013 12:29 pm
Oh, I also tried the following which was also on the same page:
sudo gpg --keyserver hkp://subkeys.pgp.net --recv-keys 82B129927FA3303
But that gave me this error:
pi@raspberrypi2 ~ $ sudo gpg --keyserver hkp://subkeys.pgp.net --recv-keys 82B129927FA3303E
gpg: requesting key 7FA3303E from hkp server subkeys.pgp.net
gpgkeys: key 82B129927FA3303E not found on keyserver
gpg: no valid OpenPGP data found.
gpg: Total number processed: 0
shuckle
Wed Jan 02, 2013 8:37 am
Yes, same issue.
I was able to recovert the other key (9165938D90FDDD2E) but failed similarly with the other as you.
Now recovering from backup. Very interesting that we run into this at the same time.
AddicusT
Thu Jan 17, 2013 12:39 am
I am also having this problem. I think it comes from modifying sources.list.
glennmcco
Thu Feb 21, 2013 5:16 pm
I am also having this problem, has anyone found a solution?
RichKavanagh
Thu Feb 21, 2013 9:29 pm
No :(
Formatted, started again :(
mhossam
Thu May 16, 2013 1:28 am
That solved the problem for me :)
wget http://archive.raspbian.org/raspbian.public.key -O - | sudo apt-key add -
fengyue5bian
Mon Dec 15, 2014 12:42 pm
The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY
Error:
GPG error: http://ftp.us.debian.org wheezy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY x0x0x0x0x0x0x0x0
Take note of the 16 digit key and place it into the following statement.
gpg --keyserver keys.gnupg.net --recv-key x0x0x0x0x0x0x0x0
gpg -a --export x0x0x0x0x0x0x0x0 | sudo apt-key add -
Problem solved! :D
Diane253
Fri Dec 19, 2014 7:14 am
After doing an update today I got the same error:
W: GPG error: http://nightly.openerp.com ./ Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY DEF2A2198183CBB5
I tried
/$ gpg --keyserver keys.gnupg.net --recv-key DEF2A2198183CBB5
Resulting:
gpg: requesting key 8183CBB5 from hkp server keys.gnupg.net
gpgkeys: key DEF2A2198183CBB5 not found on keyserver
I tried:
gpg --keyserver hkp://keyserver.ubuntu.com:80 --recv DEF2A2198183CBB5
Resulting:
gpg: requesting key 8183CBB5 from hkp server keyserver.ubuntu.com
I tried:
gpg --keyserver subkeys.pgp.net --recv-keys DEF2A2198183CBB5
Resulting:
gpg: requesting key 8183CBB5 from hkp server subkeys.pgp.net
gpg: keyserver timed out
gpg: keyserver receive failed: keyserver error[/code]
I also tried:
sudo apt-key adv --recv-keys --keyserver keyserver.ubuntu.com DEF2A2198183CBB5
And:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 8BAF9A6F
I still come up with the same error after updating.
I have installed nothing new since last time that I updated.
I could use some help, please.
brbaker
Fri Jan 08, 2016 4:56 am
This thread is old but was not resolved. I had the same issue today and found the solution here: viewtopic.php?f=91&t=114692&p=833262&hi ... EY#p833262
IgorGanapolsky
Sun Nov 27, 2016 7:34 pm
I am also getting the following error now:
> GPG error: http://debian.yeasoft.net wheezy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 40FC0CD26BF18B15
fred44nl
Tue Nov 29, 2016 9:28 pm
I have this error:
W: GPG error: https://dev2day.de jessie InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 97BC9498DC9666A8
there are many suggestions, but none solves the problem.
headless RPi 3B running from usbhdd.
tracy
Sat Apr 08, 2017 5:29 pm
This was left out of the instructions it appears:
wget -O - https://dev2day.de/pms/dev2day-pms.gpg.key | sudo apt-key add -
Paulwood
Thu May 18, 2017 1:38 am
This is happening to me using 2017-04-10-raspbian-jessie-lite.img - when I do a 'sudo apt-get update' I get
pi@aldenst:~ $ sudo apt-get update
Get:1 http://repo.mosquitto.org jessie InRelease [3,884 B]
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://archive.raspberrypi.org jessie InRelease
Ign http://repo.mosquitto.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Hit http://repo.mosquitto.org jessie/main armhf Packages
Ign http://repo.mosquitto.org jessie/main Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_US
Ign http://archive.raspberrypi.org jessie/main Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_US
Ign http://archive.raspberrypi.org jessie/ui Translation-en_US
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_US
Fetched 3,884 B in 29s (132 B/s)
W: GPG error: http://repo.mosquitto.org jessie InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 61611AE430993623
pi@aldenst:~ $
This is on a fresh install and just after the standard reboot to expand the disk.
Any solutions to this?
Gandolf_1
Mon Jan 01, 2018 9:56 pm
I am having the same problem. I have tried all the above suggestion without success. I have three observations. First this problem did not occur until I loaded MONO. Second some of the suggestion in the above posts required the DIRMNGR which is not installed . Third when I used
apt-key adv --keyserver keyserver.ubuntu.com --recv-keys A6A19B38D3D831E
The message was it was not a key ID
The orginal failure message when I tried an update was
pi@PI_2:~ $ sudo apt-get --allow-unauthenticated update
Get:1 http://download.mono-project.com/repo/debian raspbianstretch InRelease [2,224 B]
Hit:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Hit:3 http://archive.raspberrypi.org/debian stretch InRelease
Ign:1 http://download.mono-project.com/repo/debian raspbianstretch InRelease
Fetched 2,224 B in 1s (1,590 B/s)
W: GPG error: http://download.mono-project.com/repo/debian raspbianstretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY A6A19B38D3D831EF
W: The repository 'http://download.mono-project.com/repo/debian raspbianstretch InRelease' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Any suggested resolutions would be greatly appreciated.
Mon Jan 01, 2018 10:17 pm
What on earth are you doing that for?
There's a perfectly serviceable version of mono-complete available as part of plain ordinary Raspbian Stretch.
Undo all the changes you've made to /etc/apt/sources.list and files in /etc/apt/sources.list.d before you destroy your Raspian installation.
