Camera won't work when display is connected
Posted: Tue Jun 16, 2020 3:09 pm
by Vinuel
Hello everyone,
I recently got the new raspi camera module and it works totally fine. But whenever i also connect my 4.3 inch Display with the pi I get the following response:
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
Also, the WiFi really works horribly when the display is connected, but whenever I disconnect the display all works perfectly. My first guess is, that the display simply needs too much power, so my raspi 3b+ isn't able to properly use anything else.
I use the raspi 3b+ with the newest raspbian and the official power supply with 5.1V/2.5A.
If it really is the power supply, is it possible to use an additional power source? (The display is only connected via the onboard display port and doesn't have its own power supply possibility, here's a link to the display:
https://www.waveshare.com/4.3inch-dsi-lcd.htm )
Another option would be to get the new Raspi 4b, but i read, that it already needs a bit more power to run, so I'm not sure if it would be any better.
Thanks in advance for any help!
Re: Camera won't work when display is connected
Posted: Tue Jun 16, 2020 4:05 pm
by aBUGSworstnightmare
What does waveshare say? The DSI and CSI share the same I2C interface on the standard PI --> maybe waveshare did not consider this when designing the display
Posted: Tue Jun 16, 2020 4:09 pm
by Vinuel
Oh, so it may be, that the display simply "blocks" the camera, since it always needs the interface? Is there a simple way to solve this, or do i need another display?
And: 1 time(!) i was able to use the cam and the display at the same time, but it was after a reboot-orgy and i didn't really change anything!
Posted: Wed Jun 17, 2020 8:52 am
by Vinuel
just to add any more information: the raspi at least knows, that the cam is connected. Running "vcgencmd get_camera" gives me "supported=1 detected=1". It still bothers me, that the WiFi doesnt really work (it needs to be damn close to the router and the speed/ping is horrible).
Update: when using a python-script taking a picture works perfectly fine, so i guess theres a problem with raspistill/raspivid + the display? Still, wifi annoys me tho
Update 2: it was a one-timer
after rebooting and starting the pythong-script again, i get the following response:
picamera.exc.PiCameraMMALError: Failed to enable connection: Out of resources
. Sounds like my pi is simply too weak for both display + cam?
Posted: Wed Jun 17, 2020 9:28 am
by gordon77
" Sounds like my pi is simply too weak for both display + cam?"
Maybe an issue with that display. I use a Pi2 with the official 7" Pi display and a pi camera with no issues.
Posted: Wed Jun 17, 2020 9:47 am
by Vinuel
Is there a way to see if any other process is using the camera right now?
Posted: Wed Jun 17, 2020 10:00 am
by PiGraham
Based on the error message I got this from Google
viewtopic.php?t=198665#p1240002
Could be something else is using the camera
Posted: Wed Jun 17, 2020 11:34 am
by Vinuel
Yeah, already thought of that too. Problem is, that even after a clean install the problem occurs. But since it was mentioned, that the cam and the display use the same interface, maybe that's exactly the problem. Question is how to solve that problem. I mean i already got it running 2 times (1 time with raspistill, 1 time with a python script), but it's pretty random if it works or not.
Posted: Wed Jun 17, 2020 11:41 am
by jamesh
Sounds like a terrible display - bad wireless means it's electrically very noisy, and it sounds like the driver isn't right either if it's interfering with the camera.
Posted: Wed Jun 17, 2020 11:54 am
by Vinuel
Never had to install a driver, it's plug and play.
But not having wifi would be completly fine for me, it's just that i wonder if theres a context between the bad wifi and the problems with the cam
Posted: Wed Jun 17, 2020 12:05 pm
by stubright
Vinuel wrote: ↑Wed Jun 17, 2020 11:34 am
Are you sure it is not a power issue? The website states you should use a 3A power supply when using the screen.
It works with just the screen, it works with just the camera but when both are connected you state "I got it running 2 times (1 time with raspistill, 1 time with a python script), but it's pretty random if it works"
You're using a 2.5A supply with a screen AND camera and as quoted above you have had it working a couple of times, albeit randomly. I don't know how much power the camera uses, or the screen for that matter, but for them to recommend a beefier power supply just for the sceen must mean something.
Posted: Wed Jun 17, 2020 12:06 pm
by Vinuel
Can the raspi 3b handle a "better" power supply? I think i read that the one i use right now is the maximum, but not sure..
Posted: Wed Jun 17, 2020 12:18 pm
by fruitoftheloom
Vinuel wrote: ↑Wed Jun 17, 2020 12:06 pm
According to the specifications an Official Power Supply should be "adequate"
https://www.waveshare.com/wiki/4.3inch_DSI_LCD
https://www.raspberrypi.org/documentati ... /#pi-power
Posted: Wed Jun 17, 2020 12:51 pm
by Vinuel
It should be, but on rebooting i just saw the sign that the power supply is too weak (at least i guess that's what the lightning in the top right corner means). But i don't know if that's normal on reboots or not
Posted: Thu Jun 18, 2020 7:53 am
by Vinuel
Okay I'm trying to return it today, any suggestions for a display perfectly working with the pi camera? If possible < than 5 inches
