ninjahatori
Raspberry pi run startup python script cannot send HTTP requests
Tue Jun 09, 2020 4:21 am
I let my python script run at startup but some of HTTP requests (using requests pip module) not working. However, when I run the script manually with sudo openvt -s -w /path/to/launcher.sh, all HTTP requests are working fine.
this is my code in ~/.bashrc`
and in launcher.sh, it is as simple as cd to directory and run python script.
cd /path/to/python/script
python start.py
when the script is run at startup. HTTP requests throw this error:
ConnectionError: HTTPSConnectionPool(host='', port=443): Max retries exceeded with url: /my/api (Caused by <class 'socket.gaierror'>: [Errno -3] Temporary failure in name resolution)
Again, when I run the script via ssh using this command sudo openvt -s -w /path/to/launcher.sh, everything is working fine. I'm struggling this bugs for days. Thank you so much for any helps :)
pfletch101
Re: Raspberry pi run startup python script cannot send HTTP requests
Tue Jun 09, 2020 1:16 pm
How are you running the script at startup? If you are using cron and have not put in a delay, it is almost certainly running before the network is properly set up and initialized, which typically takes a long time by computer standards (a second to a few seconds). The quick and dirty fix is to have the script sleep for 10-20 seconds before trying to access the network. An arguably better fix is to loop on a try...except...finally loop which tests whether a predictably 'up' internet site (many people use google.com) is accessible. If this continues to fail after a reasonable time has elapsed, you know that something has really gone wrong, and can take appropriate action.
klricks
Tue Jun 09, 2020 3:55 pm
You might try the wait for network on boot option which you can set using GUI config tool or sudo raspi.config
pfletch101
Tue Jun 09, 2020 4:19 pm
I have found that (possibly depending on what you are trying to do over the network) this is not always sufficient. I think that 'wait for network on boot' may only wait until the local network hardware is working - it may not wait until all the handshaking involved (particularly) in a WiFi internet connection is completed. It has certainly been my experience that scripts requiring immediate internet access which are triggered on reboot can fail for network-related reasons even if 'wait for network on boot' is set.
