Lullah
Monitoring Temp of Raspbery PI
Mon Jun 08, 2020 12:44 pm
Just a quick question, is there a way to remotly monitor the temp of my raspberry pi's? with out having to SSH or VNC into the device
JovianPyx
Re: Monitoring Temp of Raspbery PI
Mon Jun 08, 2020 4:42 pm
To monitor the temperature (or anything else for that matter) you need to make some kind of connection. It doesn't have to be SSH or VNC, though they would allow temperature monitoring. Another way is to run a web server on the pi. A small light-weight one is called lighttpd. Alternatively, you can use apache2. In that case, you would construct the web server to send a page with the temperature data on it to your browser.
Hope that helps.
