benparsons
RPi4 won't connect to wifi
Sun Jun 07, 2020 10:32 am
I have a problem very similar to viewtopic.php?t=245067, but I can't find a solution.
The dropdown shows my SSID present and with good signal, but clicking it does nothing, gives no feedback.
My wpa_supplicant.conf:
pi@blueboi:~ $ cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
country=GB
network={
	ssid="SKY151A6"
	psk="(correct key)"
	key_mgmt=WPA-PSK
I've tried removing the key_mgmt field.
wpa_supplicant -Dwext -iwlan0 -c/etc/wpa_supplicant/wpa_supplicant.conf output:
pi@blueboi:~ $ sudo wpa_supplicant -Dwext -iwlan0 -c/etc/wpa_supplicant/wpa_supplicant.conf
Successfully initialized wpa_supplicant
ioctl[SIOCSIWENCODEEXT]: Invalid argument
ioctl[SIOCSIWSCAN]: Device or resource busy
wlan0: CTRL-EVENT-SCAN-FAILED ret=-1 retry=1
wlan0: Trying to associate with 70:50:af:1e:34:7d (SSID='SKY151A6' freq=2412 MHz)
Failed to add supported operating classes IE
wlan0: Authentication with 70:50:af:1e:34:7d timed out.
wlan0: CTRL-EVENT-DISCONNECTED bssid=70:50:af:1e:34:7d reason=3 locally_generated=1
ioctl[SIOCSIWSCAN]: Resource temporarily unavailable
wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="SKY151A6" auth_failures=1 duration=10 reason=CONN_FAILED
^Cwlan0: CTRL-EVENT-SSID-REENABLED id=0 ssid="SKY151A6"
^Cwlan0: CTRL-EVENT-DISCONNECTED bssid=70:50:af:1e:34:7d reason=3 locally_generated=1
wlan0: CTRL-EVENT-TERMINATING
I have noticed that sometimes, after shutting down and restarting, the Pi will connect, but there seems to be no pattern to this.
Can anyone suggest how to debug the problem or what to try next?
pidd
Re: RPi4 won't connect to wifi
Sun Jun 07, 2020 10:46 am
Have you tried putting it right next to the router, I've had interference problems even when it was 2 feet away.
thagrol
Sun Jun 07, 2020 12:22 pm
Try rebooting the router.
I've encountered routers that work fine with existing clients, show in the list of SSIDs, and appear to go through the connection process but always fail to authenticate new clients. A reboot fixed that.
Sun Jun 07, 2020 12:29 pm
Are the SSIDs for 5GHz and 2.4GHz the same on your router?
On my network with 2.4GHz SSID=Example my 5GHz is set up with SSID=Example-5G so that I can be certain who's using the 5GHz piece.
thagrol
Sun Jun 07, 2020 1:28 pm
I should add, one of the questionable router I mentioned above was supplied by Sky.
epoch1970
Sun Jun 07, 2020 1:50 pm
Remove the "-Dwext" argument from your command-line.
That is not the appropriate driver for brcmfmac.
The appropriate driver nl80211 is selected by default by wpa_supplicant.
