Hello
Like other on this board I've got a problem with my raspberry pi 4 4G.
I tried all tricks I find but I can't recover the vl805 firmware on the eeprom...
Still got my VL805 firmware version at 00000000
Does anyone got a solution ?
Hi
This and other recovery methods don't seem to work in these cases. Since the VL805 firmware is now included in the pieeprom.bin, why not use it if the version is 00000000 in the dedicated VLI EEPROM?jdb wrote: ↑Sun Jun 07, 2020 10:52 amUse a recovery SD card to reflash both the bootloader and VLI eeprom.
https://github.com/raspberrypi/rpi-eepr ... eleases.md
If they don't work then it's likely a HW problem. There should be no mechanism by which they don't work, except a HW failure of some sort.Kendek wrote: ↑Sun Jun 07, 2020 2:09 pmThis and other recovery methods don't seem to work in these cases. Since the VL805 firmware is now included in the pieeprom.bin, why not use it if the version is 00000000 in the dedicated VLI EEPROM?jdb wrote: ↑Sun Jun 07, 2020 10:52 amUse a recovery SD card to reflash both the bootloader and VLI eeprom.
