Cannot connect pi 4 to wifi for headless set up
Posted: Fri Jun 05, 2020 9:33 pm
Hi! I am rather new to raspberry pi and I am very excited for it. However I am not able to connect it to the WIFI for a headless set up. I tried following the online forums and added the ssh file to the sd card as well as wpa_supplicant.conf which looks like this in mine:
I have tried re-downloading and reformatting the sd card as suggested by user guide and still no luck. Once I try these and put sd into raspberry pi it appears to boot with lots of flashing of act green led and then when I look at my router there is no connection for raspberry pi so I do not know if it is connecting. There are some connections that are un-named but every forum I check has it popping up with a name. Maybe this was erased when I reformatted? Any help would be much appreciated and I would be happy to share any additional information!
country=US
update_config=1
network={
scan_ssid=1
ssid="***"
psk="***"
