Can't SSH int Zero W
Posted: Tue Jun 02, 2020 12:00 am
by norwestie
I just got a Pi Zero W. Using 2 different microSD cards and both Rasp Imager and Balena Etcher, adding the SSH and wpa_supplicant.conf files, it still can't be seen on my network. Being an amateur, I first tried Notepad++ to create a blank SSH doc and another for with my wifi info. I would boot the Pi and the LED would blink for a few minutes but not seen on my network. I pull the card and view in Win10. The 2 files weren't there. Redid, same problem. Next I created text files from within the desktop folder from the options in the header. Still nothing. What is my rookie mistake?
Re: Can't SSH int Zero W
Posted: Tue Jun 02, 2020 12:11 am
by HawaiianPi
Hard to say without seeing the files you created, or knowing exactly what you did.
If you have another Pi that is already configured for WiFi, you can copy the
wpa_supplicant.conf file from /etc/wpa_supplicant/ and use it on any new cards you create.
Mine looks like this.
update_config=1
country=GB
network={
ssid="WiFi SSID"
psk="WPA/WPA2 passphrase"
Edit country=, ssid= and psk= with your information and save the file.
Posted: Tue Jun 02, 2020 12:38 am
by norwestie
I've done all that and it matches the online tutorials, as well.
Posted: Tue Jun 02, 2020 12:43 am
by trejan
The files disappearing is normal and it shows that the Pi is actually running.
Do you have spaces in the SSID or password? If it has spaces then you must put double quote marks around it.
Posted: Tue Jun 02, 2020 12:45 am
by norwestie
Double quotes?!? When did this happen? I'll give that a try. Thank you!
Posted: Tue Jun 02, 2020 1:10 am
by norwestie
That didn't help. I plugged the card into my Mac and saw a .txt on the suplicant file. I removed that and rebooted but still nothing.
Posted: Tue Jun 02, 2020 4:47 am
by norwestie
I borrowed another Pi and installed a fresh OS and now it is connected!
