Sat May 30, 2020 11:22 am
Assuming you pi still works, download the latest Raspberry Pi OS (previously called Raspbian) and flash that on to another SD card.
Boot your pi using that, then place you old SD card in to a USB card reader and connect that to your pi, if you use the desktop version it should auto mount the partitions on the old SD card and then you can copy off the data you want.
