Blackbox-raspberry
Raspberry Pi OS Phone Jack Audio
Thu May 28, 2020 11:32 am
since the new Raspberry OS ist live, i have a new problem.
The command amxier cset numid=3 1 doenst work anymore. I think its because the HMDI and Phone Jack are now seperated. But how can i force the audio output to phone jack now in console?
mahjongg
Re: Raspberry Pi OS Phone Jack Audio
Thu May 28, 2020 11:45 am
just from memory..
since the release of the RPI4 the A/V audio driver has been standard disabled because leaving it on is impairing the performance of raspbian OS.
I leave it to other readers to tell you how to turn in back on, but I imagine it must either be an entry in config.txt or a menu option in raspberry-config.
Blackbox-raspberry
Thu May 28, 2020 12:00 pm
Thx for Reply.
in searched in the github repository for the raspi-config https://github.com/RPi-Distro/raspi-con ... spi-config and found the function do_audio.
You are right, i have to create file with a special content.
pcm.!default {
  type asym
  playback.pcm {
    type plug
    slave.pcm "output"
  capture.pcm {
    type plug
    slave.pcm "input"
pcm.output {
  type hw
  card 1
ctl.!default {
  type hw
  card 1
Can you please swtich the thread to the troubleshooting forum?
spl23
Thu May 28, 2020 1:08 pm
mahjongg
Thu May 28, 2020 4:54 pm
Install the latest version of raspbian (now called raspberry PI OS), it has had changes in the audio handling, and has now two separate handlers for audio, one for A/V and one for HDMI, (previously one handler did both, in an either or fashion) and so you can now turn each one on and off with a simple desktop pulldown menu.
See it explained at 4 minutes 40 seconds into this video https://www.youtube.com/watch?v=qD67xfSvQrE&frags=wn
