Sunny0101786
Bought my first Pi 4 4g but fails to boot see errors below
Sat May 09, 2020 6:15 am
Non FAT partition: 0 sectors: 168689522 type: 03
SD boot failed
BOOT_STOPPED: 0x00000001 0x0
used 2 different sd cards 64 gb and 128 gb, both are samsung evo plus. formatted to FAT32 many times. same error. not sure what i’m doing wrong. downloaded the latest version of noobs extracted and copied the files to sd cards multiple times after formatting the cards over and over. no luck.
FTrevorGowen
Re: Bought my first Pi 4 4g but fails to boot see errors below
Sat May 09, 2020 2:25 pm
SD boot failed
What, physically, are you using to format/write to the cards? Are you sure that the card slot/reader is fully SDHC and/or SDXC compatible (USB-based devices are usually labelled, card slots often aren't). Rather than use NOOBS, which requires the card to be formatted perhaps try using the new Raspberry Pi Imaging Tool instead: https://www.raspberrypi.org/downloads/ Although I can, and have used "conventional" Linux methods to write images with a Pi (or other Linux Box) I'm currently using that method** with one of my P3A+'s because it makes "life easier" :) : https://www.cpmspectrepi.uk/raspberry_p ... Aplus.html
Trev.
** with a USB-based card reader/writer
PeterO
Sat May 09, 2020 2:47 pm
Try following these instructions....
https://projects.raspberrypi.org/en/pro ... tting-up/2
PeterO
Sunny0101786
Sat May 09, 2020 6:50 pm
Raspberry pi imager worked gor LibreELEC. No issues.
But how to flash Openmediavault? Pi imager do not recognize iso image of Openmediavault. I want to boot it directly from sd card.
Sat May 09, 2020 6:56 pm
https://pimylifeup.com/raspberry-pi-openmediavault/
RPi 4B 4GB (SSD Boot)..
