I got a Pi4 B and I have 2 SD cards, onw 32 and one 64. I tried to install on both the recommended Raspbian distro from the imaging tool on a Mac. Right after the installation I added the ssh file and the wap_suppliment.conf to the boot directory - I don't have a mini HDMI monitor and I'm hoping to SSH to it and use it headlessly.
The Pi had a Sense HAT attached to it (not sure if relevant)
When start the device ( which is really annoying with USB C cable for some reason it won't start unless you plug the cable really slowly? )
The Sense HAT has a rainbow on it, but from memory of past Pis it should turn off as soon as the OS starts. It never does. And I am unable to ping ranspberrypi or find it in my router. I tried:
- Plugging it directly to the router via LAN
- WiFi connection didn't work
- Ran the recovery module from the image tool (EEPROM)
Any suggestions? I can't even see any log files as the filesystem doesn't have var/
How do I know if the OS even booted up
THANKS,
