I know this kind of problem is extremely common and dozens of questions have been asked but I still can't figure out why my new Pi 4 isn't booting.
The first time I used the RPI4 I succeeded to boot but soon after that the system crashed with a kernel error. I though it was a download problem, so I got a fresh Raspian version. After that, only a solid red light will show up. Apparently, the boot process is performed as for around 30s the green led is randomly flashing, but after that the Pi is dead, not showing up in the local ip list nor giving any output on the screen.
I am using adequate power supply, HDMI0 port and the official latest Raspian release (feb 2020) on multiple microSD 16GB cards; I also tried to toggle HDMI safe and other settings in config.txt.
I tried the EEPROM test suggested in the sticky post booting without microSD card and I get the 4 green led flashes. I successfully followed the recovery procedure downloading the newest bootloader but it didn't change anything.
Is there a Serial port or some other way to debug and understand what is really happening? If the PI is faulty, as I suspect, can I return it?
