Sat Apr 11, 2020 10:50 pm
supertp wrote: ↑Sat Apr 11, 2020 10:33 pm
Hello
I have a Pi 3 model B.
I've read (almost) all topics regarding the ways to properly shutdown a ràspberry.
Nevertheless, is it normal that the RPI reboots instead of being shutdown/halted?
I want to completely power of of without damaging the SD card.
The RPI runs in headless mode and I connect to it over ssh. Should I just plug it off after the sudo shutdown -P now and once the green led stops blinking?
Is it normal that the RPI restarts instead of shutting down?
I usually use
then wait until after the green ACTivity led has flashed 10 times and gone and then remove power by switching off at the AC supply end. Repeated "pulling out the uUSB plug" may result (have resulted) in poor connectivity / mechanical play leading to a power off/on spike that might trigger a reboot. What are you using as a power supply?
Trev.
