Tylerx
my SD-card won't keep my stuff
Sat Apr 11, 2020 12:08 am
I created a folder and several text documents and when i shut it down then went back on they were done i tryed a few times and everything time they are gone it also seems to undo things iv sent to the trash
trejan
Re: Wont keep my stuff
Sat Apr 11, 2020 12:10 am
Your SD card has failed. One of the failure modes is that it permanently goes read only in an attempt to preserve your data. What you're seeing is the result of the OS caching changes in memory. When you reboot, you lose the contents of the cache so you're seeing the unaltered card contents again. All you can do it buy a new card.
Tylerx
Sat Apr 11, 2020 1:22 am
Thanks kinda a bummer but atleast its an easy fix
