I'm being stuck in setting up my raspberry 3+ as a 4G LAN/WiFi router. I've lately discovered pi-hole project so I'd like to integrate it too in my solution, later.
My goal is to share a 4G internet access over LAN and WiFi in an isolated place and being linked to my home with openvpn.
Actually, I'm setting :
eth0 192.168.2.2
wlan0 192.168.2.3 setup as WiFi AP
wwan0 is my 4G connection
tun0 10.8.0.30
I'm probably mismatching functions between Dnsmasq, hostapd, bridge functions and my network configuration so it may be time saving to restart from the beginning with all your advices then trying to explain what I've done so far... I'll skip openvpn part, I'll manage it later.
So from a clean install of Raspbian buster I do :
setup wifi client to apt update the system
Activate ipv4 forwarding :
# Activate ip_forwarding
sudo echo 1> /proc/sys/net/ipv4/ip_forwardCode: Select all
echo "Setting up wwan0 interface and setting internet link"
if [ ! -e /sys/class/gpio/gpio4 ]; then
echo "4" > /sys/class/gpio/export
fi
echo "out" > /sys/class/gpio/gpio4/direction
echo "0" > /sys/class/gpio/gpio4/value
sleep 2
echo "1" > /sys/class/gpio/gpio4/value
sleep 5
sudo qmicli -d /dev/cdc-wdm0 --dms-set-operating-mode='online'
sleep 1
sudo qmicli -d /dev/cdc-wdm0 -w
sleep 1
sudo ip link set wwan0 down
sleep 1
echo 'Y' | sudo tee /sys/class/net/wwan0/qmi/raw_ip
sleep 1
sudo ip link set wwan0 up
sleep 1
sudo qmicli -p -d /dev/cdc-wdm0 --device-open-net='net-raw-ip|net-no-qos-header' --wds-start-network="apn='free',ip-type=4" --client-no-release-cid
sleep 1
sudo udhcpc -i wwan0
echo "Activating routing function"
sudo iptables -t nat -A POSTROUTING -o wwan0 -j MASQUERADESetup DHCP server :
sudo apt install dnsmasq
with /etc/dnsmask.conf content
# DHCP Settings
dhcp-range=192.168.2.100,192.168.2.150,255.255.255.0,12h
# Router
#dhcp-option=3,192.168.2.1
# DNS
dhcp-option=6,192.168.2.2
# Delays sending DHCPOFFER and proxydhcp replies for at least the specified number of seconds.
dhcp-mac=set:client_is_a_pi,B8:27:EB:*:*:*
dhcp-reply-delay=tag:client_is_a_pi,2sudo apt install hostapd
with /etc/hostapd/hostapd.conf content :
interface=wlan0
country_code=FR
ctrl_interface=wlan0
ctrl_interface_group=0
ssid=my_ssid
hw_mode=g
channel=7
wpa=3
wpa_passphrase=secret
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
beacon_int=100
auth_algs=3
macaddr_acl=0
wmm_enabled=1To finish, I'm having all the setup forced at startup in a script :
#!/bin/bash
echoc () {
echo -e "\e[44m$1\e[49m"
echoc "Setting up eth0 interface address to 192.168.2.2"
sudo ifconfig eth0 down
sudo ifconfig eth0 192.168.2.2
sudo ifconfig eth0 up
echoc "Setting up wlan0 interface address to 192.168.2.3"
sudo ifconfig wlan0 down
sudo ifconfig wlan0 192.168.2.3
sudo ifconfig wlan0 up
sleep 1
echoc "Restarting AP and DHCP services"
sudo service hostapd restart
sudo service dnsmasq restart
echoc "Setting up wwan0 interface and setting internet link"
fi
sleep 2
sleep 5
sleep 1
sleep 1
sleep 1
sleep 1
sleep 1
sleep 1
echoc "Activating routing function"
Regards
