Maybe it has something to do with this? :
pi@raspberrypi ~ $ arecord --list-device
**** List of CAPTURE Hardware Devices ****
When I run "pactl list" I got the following sourcd-entry:
Source #0
State: IDLE
Description: Monitor of bcm2835 ALSA Analog Stereo
Driver: module-alsa-card.c
Sample Specification: s16le 2ch 44100Hz
Channel Map: front-left,front-right
Owner Module: 4
Mute: no
Volume: 0: 100% 1: 100%
0: 0.00 dB 1: 0.00 dB
balance 0.00
Base Volume: 100%
0.00 dB
Monitor of Sink: alsa_output.platform-bcm2835_AUD0.0.analog-stereo
Latency: 0 usec, configured 99954 usec
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = "Monitor of bcm2835 ALSA Analog Stereo"
device.class = "monitor"
alsa.card = "0"
alsa.card_name = "bcm2835 ALSA"
alsa.long_card_name = "bcm2835 ALSA"
alsa.driver_name = "snd_bcm2835"
device.bus_path = "platform-bcm2835_AUD0.0"
sysfs.path = "/devices/platform/bcm2835_AUD0.0/sound/card0"
device.string = "0"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card"
Formats:
pcm
but sometimes the name is just auto_null.monitor (even while playing)
