Tue Mar 31, 2020 3:44 pm
Luk158 wrote: ↑Tue Mar 31, 2020 1:01 pm
I on boxed my new pi 4 B today and loaded Raspbian lite onto the boot SD.
I wait for the official Power Supply but till than I used the fast-Charger form Apple (and yes I checkt if the 5V etc. are right, they are, and the Charger still work.)
Since it is the lite version I know there wouldn't be a video output, so i didn't look for that.
Neither the Power nor the Activate LED blinks or glows.
It is visible on my router, when connected to it.
I tried it with the normal Raspbian distro.
Is there an on/off switch or anything that I have overlooked?
Any ideas for how to start it?
IIRC, (I rarely use Raspbian Lite) there still should be a "video output" if you connect a display but just "text", not a desktop. All output can be suppressed by editing
/boot/cmdline.txt appropriately but, AFAIK that's not the default (or, maybe, wasn't). The really odd thing is that you say "It is visible on my router, when connected to it" but appear not to see any red PoWeR or green ACTivity led behaviour. If the red PoWeR led is not on, ie. is off or blinks then your Apple charger is
not supplying power correctly. (You may be using one of the expensive leads with active circuitry within them which would not work with early P4B's). How do you know your router "see's" the Pi? (ie. what does the router report?). Finally, how (with what tools/hardware) did you write Raspbian lite to the uSDHC card (make, type, size?).
Trev.
