snupis
Serial Port Permissions
Sun Mar 22, 2020 2:33 pm
We’re having permission issues reading and writing from our Raspberry Pi Zero W’s serial port. We’re trying to use the mh-z19 Python module, but the problem can be pinpointed to starting the serial-getty service. When the service is started the permissions of the serial device change(group name and permissions). Please see below for a minimal example:
pi@raspberrypi:~ $ ls -l /dev/serial0 /dev/ttyAMA0
lrwxrwxrwx 1 root root          7 Mar 22 03:56 /dev/serial0 -> ttyAMA0
crw-rw---- 1 root dialout 204, 64 Mar 22 03:56 /dev/ttyAMA0
pi@raspberrypi:~ $ sudo systemctl start serial-getty@serial0.service
crw--w---- 1 root tty  204, 64 Mar 22 03:58 /dev/ttyAMA0
pi@raspberrypi:~ $ sudo systemctl stop serial-getty@serial0.service
pi@raspberrypi:~ $ sudo systemctl is-active serial-getty@serial0.service
inactive
The /boot/config.txt file contains:
dtoverlay=disable-bt
enable_uart=1
When running
sudo raspi-config
it indicates “The serial login shell is disabled. The serial interface is enabled.”
We want to be able to use the serial port as the user pi (who is part of the dialout group). This works fine until the getty service gets started for the first time which then changes the permissions and prevents further readings as the user pi, regardless of whether the service is stopped. How do we prevent `/dev/ttyAMA0`’s permissions from being changed when starting a service? We also tried with serial0 pointing to /dev/ttyS0 before disabling bluetooth, but it gave the exact same problem.
It’s our first time working with serial ports, so it may be something obvious we’re missing, but searching the internet hasn’t yielded any solutions.
Many thanks in advance!
hadur
Re: Serial Port Permissions
Sun Apr 12, 2020 11:41 am
Hi!
NO solution here, I have similar problem.
The settings are exactly the same like in snupis machine.
This is what happens all the time.
I set up the port with chmod (my user is in the tty, dialup groups) and after a few seconds its changed back to its original permission by 'whoknows'.
hadur@raspi:/srv/uart2 $ ls -l /dev/serial0 /dev/ttyAMA0
lrwxrwxrwx 1 root root       7 ápr   11 23:37 /dev/serial0 -> ttyAMA0
crwxrwxrwx 1 root tty  204, 64 ápr   12 13:17 /dev/ttyAMA0
hadur@raspi:/srv/uart2 $ python test2.py
0R2,Ta=023.0C,Ua=034.6P
  File "test2.py", line 13, in <module>
    timeout=1
  File "/home/hadur/.local/lib/python2.7/site-packages/serial/serialutil.py", line 240, in __init__
    self.open()
  File "/home/hadur/.local/lib/python2.7/site-packages/serial/serialposix.py", line 268, in open
    raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 13] could not open port /dev/ttyAMA0: [Errno 13] Permission denied: '/dev/ttyAMA0'
crw--w---- 1 root tty  204, 64 ápr   12 13:19 /dev/ttyAMA0
hadur@raspi:/srv/uart2 $ sudo  chmod 777  /dev/ttyAMA0
    timeout=1
    self.open()
crw--w---- 1 root tty  204, 64 ápr   12 13:20 /dev/ttyAMA0
os
hadur@raspi:/srv/uart2 $ uname -a
Linux raspi 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l GNU/Linux $
So as the problem, the question is the same as the OP's question.
hippy
Sun Apr 12, 2020 12:56 pm
You should not have to 'chmod' the port. I have experienced issues when adding groups for users and would recommended logging out and back in, or rebooting, after doing that.
bensimmo
Sun Apr 12, 2020 2:02 pm
Why are you starting serial-getty?
You didn't mention that you had disable hciuart, since you've disabled BT.
sudo systemctl disable hciuart
hadur
Mon Apr 13, 2020 10:20 am
I am not using it.
First time tried to set up the groups for my user. Rebooted and I was unable to use them still.
My last chance was to change permissions, but something allways resetting permissions back to original.
I have to communicate with another device through this serial port and cannot use sudo with it.
What is left to do ?
bensimmo
Mon Apr 13, 2020 11:50 am
is was talking about the original poster...
disable both the Getty (settings should have done this when disabling console) and then also hciuart if disabling BT
if you are running as Pi then there is no need to mess with permissions?
