AGID wrote: ↑Tue Mar 17, 2020 1:08 pmI followed your steps at this url https://installvirtual.com/how-to-insta ... mment-4437 but after "sudo ./configure --enable-optimizations" step, I rebooted mistakenly and now i cant login to desktop from vnc and not even from using hdmi. everytime i do it says “Cannot currently show the dekstop” and bring the login panel again although password is correct and no wrong password message shows up? how to fix that please?
Ign:2 http://archive.raspberrypi.org/debian stretch InRelease
Ign:3 http://repo.vivaldi.com/stable/deb stable InRelease
Get:4 http://raspbian.raspberrypi.org/raspbian stretch Release [14.4 kB]
Err:4 http://raspbian.raspberrypi.org/raspbian stretch Release
Error writing to output file - write (28: No space left on device) Error writi ng to file - write (28: No space left on device) [IP: 93.93.128.193 80]
Get:5 http://repo.vivaldi.com/stable/deb stable Release [3,831 B]
Get:6 http://repo.vivaldi.com/stable/deb stable Release.gpg [833 B]
Get:7 http://archive.raspberrypi.org/debian stretch Release [24.8 kB]
Err:7 http://archive.raspberrypi.org/debian stretch Release
Error writing to output file - write (28: No space left on device) Error writi ng to file - write (28: No space left on device) [IP: 46.235.231.111 80]
Err:6 http://repo.vivaldi.com/stable/deb stable Release.gpg
Reading package lists... Done
E: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' doe s no longer have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disa bled by default.
N: See apt-secure(8) manpage for repository creation and user configuration deta ils.
E: The repository 'http://archive.raspberrypi.org/debian stretch Release' does n o longer have a Release file.
E: The repository 'http://repo.vivaldi.com/stable/deb stable Release' is no long er signed.
N: See apt-secure(8) manpage for repository creation and user configuration deta ils.AGID wrote: ↑Tue Mar 17, 2020 3:37 pmI didn't have 3.7.3 but 3.5.3 so i had to upgrade to a newer one for some libs to work. but now i am stuck even apt-get update giving me errors
It looks like a space issue. I never had all of these Raspbian errors. Don't you think so? is it possible to remove the 3.5.3 completely in clean way?Code: Select all
Ign:2 http://archive.raspberrypi.org/debian stretch InRelease Ign:3 http://repo.vivaldi.com/stable/deb stable InRelease Get:4 http://raspbian.raspberrypi.org/raspbian stretch Release [14.4 kB] Err:4 http://raspbian.raspberrypi.org/raspbian stretch Release Error writing to output file - write (28: No space left on device) Error writi ng to file - write (28: No space left on device) [IP: 93.93.128.193 80] Get:5 http://repo.vivaldi.com/stable/deb stable Release [3,831 B] Get:6 http://repo.vivaldi.com/stable/deb stable Release.gpg [833 B] Get:7 http://archive.raspberrypi.org/debian stretch Release [24.8 kB] Err:7 http://archive.raspberrypi.org/debian stretch Release Error writing to output file - write (28: No space left on device) Error writi ng to file - write (28: No space left on device) [IP: 46.235.231.111 80] Err:6 http://repo.vivaldi.com/stable/deb stable Release.gpg Error writing to output file - write (28: No space left on device) Error writi ng to file - write (28: No space left on device) Reading package lists... Done E: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' doe s no longer have a Release file. N: Updating from such a repository can't be done securely, and is therefore disa bled by default. N: See apt-secure(8) manpage for repository creation and user configuration deta ils. E: The repository 'http://archive.raspberrypi.org/debian stretch Release' does n o longer have a Release file. N: Updating from such a repository can't be done securely, and is therefore disa bled by default. N: See apt-secure(8) manpage for repository creation and user configuration deta ils. E: The repository 'http://repo.vivaldi.com/stable/deb stable Release' is no long er signed. N: Updating from such a repository can't be done securely, and is therefore disa bled by default. N: See apt-secure(8) manpage for repository creation and user configuration deta ils.
AGID wrote: ↑Tue Mar 17, 2020 3:37 pmIt looks like a space issue. I never had all of these Raspbian errors. Don't you think so?Code: Select all
