beta-tester
how to use xarchiver to extract files with same file name?
Sun Mar 15, 2020 6:12 pm
hello,
i have a tar archive, that contains multiple files with the same file name in different versions.
e.g. creating that kind of tar archive:
echo test-1 > test.txt
tar -ravf test.tar.xz test.txt
echo test-2 > test.txt
echo test-3 > test.txt
echo test-4 > test.txt
to extract all versions of files from command console:
tar --backup=numbered -xavf test.tar.xz
but how can i open the individual files in xarchiver?
Screenshot from 2020-03-15 19-04-51.png (39.77 KiB) Viewed 140 times
when i double-click to each of those test.txt files, i always get the most recent content in the editor (with "test-4").
same, when i click extract selected file, i only the the last version of the test.txt with "test-4".
i have the newest Raspbian version installed and upgraded.
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
Botspot
Re: how to use xarchiver to extract files with same file name?
Thu May 07, 2020 8:54 pm
That's an issue with many programs - when you have multiple files of the same name, you run into trouble.
Solution: Change the filenames to be unique. If that's not an option, then you'll have to extract the entire archive and open your files using File Manager.
Want to make your own Raspbian image?
  • Hard way: Mess with confusing terminal commands.
  • Easy way: Let Pi-Power-Tools do it all for you!
Boot your image in a VM, Flash from the Internet at top speed, Mount (to drop files in), Edit partitions, Shrink/Expand, Repair, and more. Enjoy! :)
https://github.com/Botspot/Pi-Power-Tools
