tinyker
[email protected] Hz not working, tried everything I could
Sun Mar 15, 2020 8:32 am
Let's start with the hardware list:
- RPi 4B 4GB
- Official PSU
- Official microHDMI to HDMI
- Projector Viewsonic PX727 (page 50 of the manual clearly indicates it is capable of [email protected] on its HDMI1 port http://www.viewsonicglobal.com/public/p ... G.pdf?pass )
OS:
-Freshly installed and updated Raspbian (downloaded 15th of March)
Linux raspberrypi 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l GNU/Linux
Steps taken/tested:
- Projector with main PC : [email protected] achieved without problems, I left the projector's configuration untouched as that should be fine and used the same HDMI port of the projector for the RPi. This was tested using Linux Mint.
- Projector connected to HDMI0 (closest to USBC connector) of RPi as it is the only output that seems to support 60Hz
- Added
hdmi_enable_4kp60=1
to config.txt
- Rebooted, went to Display configuration GUI menu and the only options are 30Hz and below.
- checked EDID:
/opt/vc/bin/edidparser edid.dat
Enabling fuzzy format match...
Parsing edid.dat...
HDMI:EDID version 1.3, 1 extensions, unknown aspect ratio
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr444|YCbCr422; sRGB is default colourspace; preferred format is native; support GTF
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 23-120 Hz, horizontal is 15-135 kHz, max pixel clock is 600 MHz
HDMI:EDID monitor range default GTF supported
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is ViewSonic_PJ
HDMI:EDID found preferred CEA detail timing format: 3840x2160p @ 60 Hz (97)
HDMI:EDID found CEA detail timing format: 3840x2160p @ 30 Hz (95)
HDMI:EDID established timing I/II bytes are BD EF 80
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 5, 640x480p @ 72 Hz in established timing I/II
HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 10, 800x600p @ 72 Hz in established timing I/II
HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 17, 1024x768p @ 70 Hz in established timing I/II
HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
HDMI:EDID standard timings block x 8: 0x81C0 8100 8180 9500 A940 D1C0 617C 813C
HDMI:EDID found DMT format: code 85, 1280x720p @ 60 Hz (16:9) in standard timing 0
HDMI:EDID found DMT format: code 28, 1280x800p @ 60 Hz (16:10) in standard timing 1
HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 2
HDMI:EDID found DMT format: code 47, 1440x900p @ 60 Hz (16:10) in standard timing 3
HDMI:EDID found DMT format: code 51, 1600x1200p @ 60 Hz (4:3) in standard timing 4
HDMI:EDID found DMT format: code 82, 1920x1080p @ 60 Hz (16:9) in standard timing 5
HDMI:EDID found DMT format: code 20, 1024x768p @ 120 Hz (4:3) in standard timing 6
HDMI:EDID found DMT format: code 31, 1280x800p @ 120 Hz (16:10) in standard timing 7
HDMI:EDID parsing v3 CEA extension 0
HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
HDMI:EDID found CEA detail timing format: 3840x2160p @ 60 Hz (97)
HDMI:EDID found CEA detail timing format: 1920x1080p @ 60 Hz (16)
HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
HDMI:EDID found CEA format: code 39, 1920x1080i @ 50Hz
HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
HDMI:EDID found CEA format: code 33, 1920x1080p @ 25Hz
HDMI:EDID found CEA format: code 34, 1920x1080p @ 30Hz
HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 93, 3840x2160p @ 24Hz
HDMI:EDID found CEA format: code 94, 3840x2160p @ 25Hz
HDMI:EDID found CEA format: code 95, 3840x2160p @ 30Hz
HDMI:EDID found CEA format: code 96, 3840x2160p @ 50Hz
HDMI:EDID found CEA format: code 97, 3840x2160p @ 60Hz
HDMI:EDID extended data block tag 0x05 length 3 not supported
HDMI:EDID found Video Capability DB length 2
HDMI:EDID video capability: CE:3 IT:3 PT:3 QS:3
HDMI:EDID extended data block tag 0x06 length 6 not supported
HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
HDMI:EDID found HDMI VSDB length 7
HDMI:EDID HDMI VSDB has physical address 1.0.0.0
HDMI:EDID HDMI VSDB supports AI:no, dual link DVI:no
HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:yes
HDMI:EDID HDMI VSDB max TMDS clock 300 MHz
HDMI:EDID HDMI VSDB has no latency information
HDMI:EDID ignoring non HDMI VSDB with IEEE reg 0xc45dd8
HDMI:EDID extended data block tag YCbCr420VideoData - length 3
HDMI:EDID Disabling mode 96 as YUV420 only
HDMI:EDID Disabling mode 97 as YUV420 only
HDMI:EDID filtering formats with pixel clock unlimited MHz or h. blanking unlimited
HDMI:EDID best score mode initialised to CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0)
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 61864)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 66472)
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 135592)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 18432
HDMI:EDID best score mode is now CEA (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz (score 149416)
HDMI:EDID DMT mode (5) 640x480p @ 72 Hz with pixel clock 31 MHz has a score of 5529
HDMI:EDID CEA mode (6) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID DMT mode (6) 640x480p @ 75 Hz with pixel clock 31 MHz has a score of 5760
HDMI:EDID CEA mode (7) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID DMT mode (9) 800x600p @ 60 Hz with pixel clock 40 MHz has a score of 28800
HDMI:EDID DMT mode (10) 800x600p @ 72 Hz with pixel clock 50 MHz has a score of 8640
HDMI:EDID DMT mode (11) 800x600p @ 75 Hz with pixel clock 49 MHz has a score of 9000
HDMI:EDID best score mode is now CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz (score 3273832)
HDMI:EDID DMT mode (16) 1024x768p @ 60 Hz with pixel clock 65 MHz has a score of 47185
HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID DMT mode (17) 1024x768p @ 70 Hz with pixel clock 75 MHz has a score of 13762
HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID DMT mode (18) 1024x768p @ 75 Hz with pixel clock 78 MHz has a score of 14745
HDMI:EDID CEA mode (19) 1280x720p @ 50 Hz with pixel clock 74 MHz has a score of 117160
HDMI:EDID CEA mode (20) 1920x1080i @ 50 Hz with pixel clock 74 MHz has a score of 128680
HDMI:EDID DMT mode (20) 1024x768p @ 120 Hz with pixel clock 115 MHz has a score of 48592
HDMI:EDID CEA mode (21) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (22) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID DMT mode (28) 1280x800p @ 60 Hz with pixel clock 83 MHz has a score of 86440
HDMI:EDID CEA mode (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz has a score of 232360
HDMI:EDID DMT mode (31) 1280x800p @ 120 Hz with pixel clock 146 MHz has a score of 55720
HDMI:EDID CEA mode (32) 1920x1080p @ 24 Hz with pixel clock 74 MHz has a score of 124532
HDMI:EDID CEA mode (33) 1920x1080p @ 25 Hz with pixel clock 74 MHz has a score of 128680
HDMI:EDID CEA mode (34) 1920x1080p @ 30 Hz with pixel clock 74 MHz has a score of 149416
HDMI:EDID DMT mode (35) 1280x1024p @ 60 Hz with pixel clock 108 MHz has a score of 103643
HDMI:EDID DMT mode (36) 1280x1024p @ 75 Hz with pixel clock 135 MHz has a score of 24576
HDMI:EDID CEA mode (39) 1920x1080i @ 50 Hz with pixel clock 72 MHz has a score of 128680
HDMI:EDID DMT mode (47) 1440x900p @ 60 Hz with pixel clock 106 MHz has a score of 102760
HDMI:EDID DMT mode (51) 1600x1200p @ 60 Hz with pixel clock 162 MHz has a score of 140200
HDMI:EDID DMT mode (82) 1920x1080p @ 60 Hz with pixel clock 148 MHz has a score of 149416
HDMI:EDID DMT mode (85) 1280x720p @ 60 Hz with pixel clock 74 MHz has a score of 80296
HDMI:EDID CEA mode (93) 3840x2160p @ 24 Hz with pixel clock 297 MHz has a score of 423130
HDMI:EDID CEA mode (94) 3840x2160p @ 25 Hz with pixel clock 297 MHz has a score of 439720
HDMI:EDID best score mode is now CEA (95) 3840x2160p @ 30 Hz with pixel clock 297 MHz (score 5022664)
HDMI0:EDID preferred mode is updated to CEA (95) 3840x2160p @ 30 Hz with pixel clock 297000000 Hz
HDMI:EDID has HDMI support and audio support
/opt/vc/bin/edidparser exited with code 0
It seems like there could be some clue around
but I do not know how to interpret this.
- Tried to force mode 97 in config.txt, but nothing changed:
hdmi_group=1
hdmi_mode=97
-Disabled 3d acceleration:
#dtoverlay=vc4-fkms-v3d
I have exhausted all the ideas and fixes I have seen on the forum. I also installed Libreelec+Kodi to see if it would solve it, but the same issue is there as well: the max refresh rate on the menu is 30Hz.
Please, help!
Edit:
I have seen some admins asking for raw edid in base64, so here it is:
AP///////wBaYzWl7QMAADIcAQOAAAB4Dx/jpFhOmyQPS2K974CBwIEAgYCVAKlA0cBhfIE8COgA
MPJwWoCwWIoAAAAAAAAeBHQAMPJwWoCwWIoAAAAAAAAeAAAA/QAXeA+HPAAKICAgICAgAAAA/ABW
aWV3U29uaWMgUEoKAacCA0dxWBAFBAIHFgEUHxITJyAhIgMGERVdXl9gYeMF4AHiAP/mBgcBi2AS
IwkHB4MBAABnAwwAEAA4PGfYXcQBeMAD4w5gYQR0ADDycFqAsFiKAAAAAAAAHgjoADDycFqAsFiK
AAAAAAAAHgI6gBhxOC1AWCxFACDCMQAAHgAAoQ==
Botspot
Re: [email protected] Hz not working, tried everything I could
Sat Mar 21, 2020 2:18 pm
Either the Pi is not recognizing the projector properly, or the Pi has not been configured properly.
Try enabling 4k60 using sudo raspi-config.
Want to make your own Raspbian image?
  • Hard way: Mess with confusing terminal commands.
  • Easy way: Let Pi-Power-Tools do it all for you!
Boot your image in a VM, Flash from the Internet at top speed, Mount (to drop files in), Edit partitions, Shrink/Expand, Repair, and more. Enjoy! :)
https://github.com/Botspot/Pi-Power-Tools
6by9
Sun Mar 22, 2020 2:39 pm
Use edid-decode rather than edid parser, and post the raw edid if you want analysis.
base64 /sys/class/drm/card1-HDMI-A-1/edid > edid.txt
Hdmi supports a number of different colour formats. Most common is rgb888 which uses 24 bits per pixel.
Yuv (or sometimes called YCbCr) represents images as luminance (monochrome) and then chrominance (the difference from mono for the two colour channels). As the eye is less sensitive to colour it is possible to reduce the resolution of the chrominance channels without perceived loss of quality.
Yuv 4:4:4 is all 3 signals at full resolution, so 24 bits/pixel, same as rgb 888.
Yuv 4:2:2 subsamples the chroma by a factor of 2 horizontally, so effectively 16bits/pixel.
Yuv 4:2:0 subsamples the chroma by a factor of 2 both horizontally and vertically, so 12bits/pixel.
Some displays support some resolutions only in yuv4:2:0 modes. The pi currently doesn't support producing anything other than rgb888. In theory it can do yuv4:4:4 and yuv4:2:2, but not yuv4:2:0.
If your projector can only do 4k60 as yuv4:2:0 then I'm afraid you can't drive it from a Pi. The edid should reveal whether that is really the case.
tinyker
Thu Mar 26, 2020 11:40 am
Thanks for your reply and the information. I just ran the command and here is the output (I thought what I had included at the end of my original post could have been different but it's the same):
Thanks for helping
6by9
Thu Mar 26, 2020 12:08 pm
I hadn't seen the update to your first post. Unless you're amending the post within the first 5 minutes or so, please make it a new post otherwise generally people won't go back and look.
The output from edid-decode for that EDID is
edid-decode (hex):
00 ff ff ff ff ff ff 00 5a 63 35 a5 ed 03 00 00
32 1c 01 03 80 00 00 78 0f 1f e3 a4 58 4e 9b 24
0f 4b 62 bd ef 80 81 c0 81 00 81 80 95 00 a9 40
d1 c0 61 7c 81 3c 08 e8 00 30 f2 70 5a 80 b0 58
8a 00 00 00 00 00 00 1e 04 74 00 30 f2 70 5a 80
b0 58 8a 00 00 00 00 00 00 1e 00 00 00 fd 00 17
78 0f 87 3c 00 0a 20 20 20 20 20 20 00 00 00 fc
00 56 69 65 77 53 6f 6e 69 63 20 50 4a 0a 01 a7
02 03 47 71 58 10 05 04 02 07 16 01 14 1f 12 13
27 20 21 22 03 06 11 15 5d 5e 5f 60 61 e3 05 e0
01 e2 00 ff e6 06 07 01 8b 60 12 23 09 07 07 83
01 00 00 67 03 0c 00 10 00 38 3c 67 d8 5d c4 01
78 c0 03 e3 0e 60 61 04 74 00 30 f2 70 5a 80 b0
58 8a 00 00 00 00 00 00 1e 08 e8 00 30 f2 70 5a
80 b0 58 8a 00 00 00 00 00 00 1e 02 3a 80 18 71
38 2d 40 58 2c 45 00 20 c2 31 00 00 1e 00 00 a1
Block 0, Base EDID:
  EDID Structure Version & Revision: 1.3
  Vendor & Product Identification:
    Manufacturer: VSC
    Model: 42293
    Serial Number: 1005
    Made in: week 50 of 2018
  Basic Display Parameters & Features:
    Digital display
    Image size is variable
    Gamma: 2.20
    RGB color display
    Default (sRGB) color space is primary color space
    First detailed timing is preferred timing
    Supports GTF timings within operating range
  Color Characteristics:
    Red  : 0.6406, 0.3447
    Green: 0.3076, 0.6083
    Blue : 0.1435, 0.0605
    White: 0.2929, 0.3857
  Established Timings I & II:
    IBM     :   720x400    70.082 Hz   9:5    31.467 kHz  28.320 MHz
    DMT 0x04:   640x480    59.940 Hz   4:3    31.469 kHz  25.175 MHz
    Apple   :   640x480    66.667 Hz   4:3    35.000 kHz  30.240 MHz
    DMT 0x05:   640x480    72.809 Hz   4:3    37.861 kHz  31.500 MHz
    DMT 0x06:   640x480    75.000 Hz   4:3    37.500 kHz  31.500 MHz
    DMT 0x09:   800x600    60.317 Hz   4:3    37.879 kHz  40.000 MHz
    DMT 0x0a:   800x600    72.188 Hz   4:3    48.077 kHz  50.000 MHz
    DMT 0x0b:   800x600    75.000 Hz   4:3    46.875 kHz  49.500 MHz
    Apple   :   832x624    74.551 Hz   4:3    49.726 kHz  57.284 MHz
    DMT 0x10:  1024x768    60.004 Hz   4:3    48.363 kHz  65.000 MHz
    DMT 0x11:  1024x768    70.069 Hz   4:3    56.476 kHz  75.000 MHz
    DMT 0x12:  1024x768    75.029 Hz   4:3    60.023 kHz  78.750 MHz
    DMT 0x24:  1280x1024   75.025 Hz   5:4    79.976 kHz 135.000 MHz
    Apple   :  1152x870    75.062 Hz 192:145  68.681 kHz 100.000 MHz
  Standard Timings:
    DMT 0x55:  1280x720    60.000 Hz  16:9    45.000 kHz  74.250 MHz
    DMT 0x1c:  1280x800    59.810 Hz  16:10   49.702 kHz  83.500 MHz
    DMT 0x23:  1280x1024   60.020 Hz   5:4    63.981 kHz 108.000 MHz
    DMT 0x2f:  1440x900    59.887 Hz  16:10   55.935 kHz 106.500 MHz
    DMT 0x33:  1600x1200   60.000 Hz   4:3    75.000 kHz 162.000 MHz
    DMT 0x52:  1920x1080   60.000 Hz  16:9    67.500 kHz 148.500 MHz
    GTF     :  1024x768   120.000 Hz   4:3    98.760 kHz 139.054 MHz
    GTF     :  1280x800   120.000 Hz  16:10  102.960 kHz 181.210 MHz
  Detailed Timing Descriptors:
    DTD 1:  3840x2160   60.000 Hz  16:9   135.000 kHz 594.000 MHz
                 Hfront  176 Hsync  88 Hback 296 Hpol P
                 Vfront    8 Vsync  10 Vback  72 Vpol P
    DTD 2:  3840x2160   30.000 Hz  16:9    67.500 kHz 297.000 MHz
  Display Range Limits:
    Monitor ranges (GTF): 23-120 Hz V, 15-135 kHz H, max dotclock 600 MHz
    Display Product Name: 'ViewSonic PJ'
  Extension blocks: 1
Checksum: 0xa7
Block 1, CTA-861 Extension Block:
  Revision: 3
  Basic audio support
  Supports YCbCr 4:4:4
  Supports YCbCr 4:2:2
  Native detailed modes: 1
  Video Data Block:
    VIC  16:  1920x1080   60.000 Hz  16:9    67.500 kHz 148.500 MHz
    VIC   5:  1920x1080i  60.000 Hz  16:9    33.750 kHz  74.250 MHz
    VIC   4:  1280x720    60.000 Hz  16:9    45.000 kHz  74.250 MHz
    VIC   2:   720x480    59.940 Hz   4:3    31.469 kHz  27.000 MHz
    VIC   7:  1440x480i   59.940 Hz  16:9    15.734 kHz  27.000 MHz
    VIC  22:  1440x576i   50.000 Hz  16:9    15.625 kHz  27.000 MHz
    VIC   1:   640x480    59.940 Hz   4:3    31.469 kHz  25.175 MHz
    VIC  20:  1920x1080i  50.000 Hz  16:9    28.125 kHz  74.250 MHz
    VIC  31:  1920x1080   50.000 Hz  16:9    56.250 kHz 148.500 MHz
    VIC  18:   720x576    50.000 Hz  16:9    31.250 kHz  27.000 MHz
    VIC  19:  1280x720    50.000 Hz  16:9    37.500 kHz  74.250 MHz
    VIC  39:  1920x1080i  50.000 Hz  16:9    31.250 kHz  72.000 MHz
    VIC  32:  1920x1080   24.000 Hz  16:9    27.000 kHz  74.250 MHz
    VIC  33:  1920x1080   25.000 Hz  16:9    28.125 kHz  74.250 MHz
    VIC  34:  1920x1080   30.000 Hz  16:9    33.750 kHz  74.250 MHz
    VIC   3:   720x480    59.940 Hz  16:9    31.469 kHz  27.000 MHz
    VIC   6:  1440x480i   59.940 Hz   4:3    15.734 kHz  27.000 MHz
    VIC  17:   720x576    50.000 Hz   4:3    31.250 kHz  27.000 MHz
    VIC  21:  1440x576i   50.000 Hz   4:3    15.625 kHz  27.000 MHz
    VIC  93:  3840x2160   24.000 Hz  16:9    54.000 kHz 297.000 MHz
    VIC  94:  3840x2160   25.000 Hz  16:9    56.250 kHz 297.000 MHz
    VIC  95:  3840x2160   30.000 Hz  16:9    67.500 kHz 297.000 MHz
    VIC  96:  3840x2160   50.000 Hz  16:9   112.500 kHz 594.000 MHz
    VIC  97:  3840x2160   60.000 Hz  16:9   135.000 kHz 594.000 MHz
  Colorimetry Data Block:
    BT2020cYCC
    BT2020YCC
    BT2020RGB
  Video Capability Data Block:
    YCbCr quantization: Selectable (via AVI YQ)
    RGB quantization: Selectable (via AVI Q)
    PT scan behavior: Supports both over- and underscan
    IT scan behavior: Supports both over- and underscan
    CE scan behavior: Supports both over- and underscan
  HDR Static Metadata Data Block:
    Electro optical transfer functions:
      Traditional gamma - SDR luminance range
      Traditional gamma - HDR luminance range
      SMPTE ST2084
    Supported static metadata descriptors:
      Static metadata type 1
    Desired content max luminance: 139 (1015.241 cd/m^2)
    Desired content max frame-average luminance: 96 (400.000 cd/m^2)
    Desired content min luminance: 18 (0.051 cd/m^2)
  Audio Data Block:
    Linear PCM:
      Max channels: 2
      Supported sample rates (kHz): 48 44.1 32
      Supported sample sizes (bits): 24 20 16
  Speaker Allocation Data Block:
    FL/FR - Front Left/Right
  Vendor-Specific Data Block (HDMI), OUI 00-0C-03:
    Source physical address: 1.0.0.0
    DC_36bit
    DC_30bit
    DC_Y444
    Maximum TMDS clock: 300 MHz
  Vendor-Specific Data Block (HDMI Forum), OUI C4-5D-D8:
    Version: 1
    Maximum TMDS Character Rate: 600 MHz
    SCDC Present
    SCDC Read Request Capable
    Supports 12-bits/component Deep Color 4:2:0 Pixel Encoding
    Supports 10-bits/component Deep Color 4:2:0 Pixel Encoding
  YCbCr 4:2:0 Video Data Block:
    VIC  96:  3840x2160   50.000 Hz  16:9    56.250 kHz 297.000 MHz
    VIC  97:  3840x2160   60.000 Hz  16:9    67.500 kHz 297.000 MHz
    DTD 3:  3840x2160   30.000 Hz  16:9    67.500 kHz 297.000 MHz
    DTD 4:  3840x2160   60.000 Hz  16:9   135.000 kHz 594.000 MHz
    DTD 5:  1920x1080   60.000 Hz  16:9    67.500 kHz 148.500 MHz (800 mm x 450 mm)
                 Hfront   88 Hsync  44 Hback 148 Hpol P
                 Vfront    4 Vsync   5 Vback  36 Vpol P
Checksum: 0xa1
[email protected]:~/edids $
Enabling the kernel EDID parsing debug we get
[   19.425207] [drm:drm_add_display_info [drm]] HDMI: DVI dual 0, max TMDS clock 300000 kHz
[   19.425386] [drm:drm_add_display_info [drm]] HF-VSDB: max TMDS clock 600000 kHz
[   19.429455] [drm:drm_mode_debug_printmodeline [drm]] Modeline "3840x2160": 60 594000 3840 4016 4104 4400 2160 2168 2178 2250 0x48 0x5
[   19.429637] [drm:drm_mode_prune_invalid [drm]] Not using 3840x2160 mode: NO_420
[   19.429822] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1024x768": 0 115500 1024 1072 1104 1184 768 771 775 813 0x40 0x9
[   19.430002] [drm:drm_mode_prune_invalid [drm]] Not using 1024x768 mode: BAD_VVALUE
[   19.430187] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x800": 0 146250 1280 1328 1360 1440 800 803 809 847 0x40 0x9
[   19.430366] [drm:drm_mode_prune_invalid [drm]] Not using 1280x800 mode: BAD_VVALUE
[   19.430553] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1080i": 0 74250 1920 2008 2052 2200 1080 1084 1094 1125 0x40 0x15
[   19.430732] [drm:drm_mode_prune_invalid [drm]] Not using 1920x1080i mode: NO_INTERLACE
[   19.430919] [drm:drm_mode_debug_printmodeline [drm]] Modeline "720x480i": 0 13500 720 739 801 858 480 488 494 525 0x40 0x101a
[   19.431097] [drm:drm_mode_prune_invalid [drm]] Not using 720x480i mode: NO_INTERLACE
[   19.431283] [drm:drm_mode_debug_printmodeline [drm]] Modeline "720x576i": 0 13500 720 732 795 864 576 580 586 625 0x40 0x101a
[   19.431461] [drm:drm_mode_prune_invalid [drm]] Not using 720x576i mode: NO_INTERLACE
[   19.431647] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1080i": 0 74250 1920 2448 2492 2640 1080 1084 1094 1125 0x40 0x15
[   19.431826] [drm:drm_mode_prune_invalid [drm]] Not using 1920x1080i mode: NO_INTERLACE
[   19.432108] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1080i": 0 72000 1920 1952 2120 2304 1080 1126 1136 1250 0x40 0x19
[   19.432324] [drm:drm_mode_prune_invalid [drm]] Not using 1920x1080i mode: NO_INTERLACE
[   19.432512] [drm:drm_mode_debug_printmodeline [drm]] Modeline "720x480i": 0 13500 720 739 801 858 480 488 494 525 0x40 0x101a
[   19.432692] [drm:drm_mode_prune_invalid [drm]] Not using 720x480i mode: NO_INTERLACE
[   19.432878] [drm:drm_mode_debug_printmodeline [drm]] Modeline "720x576i": 0 13500 720 732 795 864 576 580 586 625 0x40 0x101a
[   19.433061] [drm:drm_mode_prune_invalid [drm]] Not using 720x576i mode: NO_INTERLACE
[   19.433249] [drm:drm_mode_debug_printmodeline [drm]] Modeline "3840x2160": 0 594000 3840 4896 4984 5280 2160 2168 2178 2250 0x40 0x5
[   19.433563] [drm:drm_mode_prune_invalid [drm]] Not using 3840x2160 mode: NO_420
[   19.433750] [drm:drm_mode_debug_printmodeline [drm]] Modeline "3840x2160": 0 594000 3840 4016 4104 4400 2160 2168 2178 2250 0x40 0x5
[   19.433929] [drm:drm_mode_prune_invalid [drm]] Not using 3840x2160 mode: NO_420
[   19.434119] [drm:drm_mode_debug_printmodeline [drm]] Modeline "3840x2160": 60 593407 3840 4016 4104 4400 2160 2168 2178 2250 0x40 0x5
[   19.434297] [drm:drm_mode_prune_invalid [drm]] Not using 3840x2160 mode: NO_420
[   19.434483] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1080i": 60 74176 1920 2008 2052 2200 1080 1084 1094 1125 0x40 0x15
[   19.434666] [drm:drm_mode_prune_invalid [drm]] Not using 1920x1080i mode: NO_INTERLACE
[   19.434851] [drm:drm_mode_debug_printmodeline [drm]] Modeline "720x480i": 60 13514 720 739 801 858 480 488 494 525 0x40 0x101a
[   19.435030] [drm:drm_mode_prune_invalid [drm]] Not using 720x480i mode: NO_INTERLACE
[   19.435218] [drm:drm_mode_debug_printmodeline [drm]] Modeline "720x480i": 60 13514 720 739 801 858 480 488 494 525 0x40 0x101a
[   19.435397] [drm:drm_mode_prune_invalid [drm]] Not using 720x480i mode: NO_INTERLACE
[   19.435582] [drm:drm_mode_debug_printmodeline [drm]] Modeline "800x600": 0 73250 800 848 880 960 600 603 607 636 0x40 0x9
[   19.435765] [drm:drm_mode_prune_invalid [drm]] Not using 800x600 mode: BAD_VVALUE
[   19.435950] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1024x768i": 0 44900 1024 1032 1208 1264 768 768 776 817 0x40 0x15
[   19.436129] [drm:drm_mode_prune_invalid [drm]] Not using 1024x768i mode: NO_INTERLACE
[   19.436315] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x768": 0 140250 1280 1328 1360 1440 768 771 778 813 0x40 0x9
[   19.436494] [drm:drm_mode_prune_invalid [drm]] Not using 1280x768 mode: BAD_VVALUE
[   19.436680] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x960": 0 175500 1280 1328 1360 1440 960 963 967 1017 0x40 0x9
[   19.436862] [drm:drm_mode_prune_invalid [drm]] Not using 1280x960 mode: BAD_VVALUE
[   19.437048] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x1024": 0 187250 1280 1328 1360 1440 1024 1027 1034 1084 0x40 0x9
[   19.437226] [drm:drm_mode_prune_invalid [drm]] Not using 1280x1024 mode: BAD_VVALUE
[   19.437409] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1360x768": 0 148250 1360 1408 1440 1520 768 771 776 813 0x40 0x9
[   19.437587] [drm:drm_mode_prune_invalid [drm]] Not using 1360x768 mode: BAD_VVALUE
[   19.437770] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1400x1050": 0 208000 1400 1448 1480 1560 1050 1053 1057 1112 0x40 0x9
[   19.437949] [drm:drm_mode_prune_invalid [drm]] Not using 1400x1050 mode: BAD_VVALUE
[   19.438132] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1440x900": 0 182750 1440 1488 1520 1600 900 903 909 953 0x40 0x9
[   19.438310] [drm:drm_mode_prune_invalid [drm]] Not using 1440x900 mode: BAD_VVALUE
[   19.438497] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1680x1050": 0 245500 1680 1728 1760 1840 1050 1053 1059 1112 0x40 0x9
[   19.438677] [drm:drm_mode_prune_invalid [drm]] Not using 1680x1050 mode: BAD_VVALUE
[   19.438816] [drm:drm_helper_probe_single_connector_modes [drm_kms_helper]] [CONNECTOR:54:HDMI-A-1] probed modes :
[   19.439001] [drm:drm_mode_debug_printmodeline [drm]] Modeline "3840x2160": 30 297000 3840 4016 4104 4400 2160 2168 2178 2250 0x40 0x5
[   19.439183] [drm:drm_mode_debug_printmodeline [drm]] Modeline "3840x2160": 30 297000 3840 4016 4104 4400 2160 2168 2178 2250 0x40 0x5
[   19.439365] [drm:drm_mode_debug_printmodeline [drm]] Modeline "3840x2160": 30 296703 3840 4016 4104 4400 2160 2168 2178 2250 0x40 0x5
[   19.439549] [drm:drm_mode_debug_printmodeline [drm]] Modeline "3840x2160": 25 297000 3840 4896 4984 5280 2160 2168 2178 2250 0x40 0x5
[   19.439730] [drm:drm_mode_debug_printmodeline [drm]] Modeline "3840x2160": 24 297000 3840 5116 5204 5500 2160 2168 2178 2250 0x40 0x5
[   19.439912] [drm:drm_mode_debug_printmodeline [drm]] Modeline "3840x2160": 24 296703 3840 5116 5204 5500 2160 2168 2178 2250 0x40 0x5
[   19.440094] [drm:drm_mode_debug_printmodeline [drm]] Modeline "2560x1600": 75 443250 2560 2768 3048 3536 1600 1603 1609 1672 0x40 0x6
[   19.440275] [drm:drm_mode_debug_printmodeline [drm]] Modeline "2560x1600": 60 268500 2560 2608 2640 2720 1600 1603 1609 1646 0x40 0x9
[   19.440457] [drm:drm_mode_debug_printmodeline [drm]] Modeline "2048x1536": 60 267027 2048 2200 2424 2800 1536 1537 1540 1589 0x0 0x6
[   19.440638] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1440": 75 297000 1920 2064 2288 2640 1440 1441 1444 1500 0x40 0x6
[   19.440819] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1440": 60 234000 1920 2048 2256 2600 1440 1441 1444 1500 0x40 0x6
[   19.441000] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1856x1392": 75 288000 1856 1984 2208 2560 1392 1393 1396 1500 0x40 0x6
[   19.441181] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1856x1392": 60 218250 1856 1952 2176 2528 1392 1393 1396 1439 0x40 0x6
[   19.441363] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1792x1344": 75 261000 1792 1888 2104 2456 1344 1345 1348 1417 0x40 0x6
[   19.441544] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1792x1344": 60 204750 1792 1920 2120 2448 1344 1345 1348 1394 0x40 0x6
[   19.441725] [drm:drm_mode_debug_printmodeline [drm]] Modeline "2048x1152": 60 162000 2048 2074 2154 2250 1152 1153 1156 1200 0x40 0x5
[   19.441907] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1200": 85 281250 1920 2064 2272 2624 1200 1203 1209 1262 0x40 0x6
[   19.442129] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1200": 75 245250 1920 2056 2264 2608 1200 1203 1209 1255 0x40 0x6
[   19.442318] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1200": 60 154000 1920 1968 2000 2080 1200 1203 1209 1235 0x40 0x9
[   19.442500] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1080": 60 148500 1920 2008 2052 2200 1080 1084 1089 1125 0x40 0x5
[   19.442684] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1080": 60 148500 1920 2008 2052 2200 1080 1084 1089 1125 0x40 0x5
[   19.442870] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1080": 60 148352 1920 2008 2052 2200 1080 1084 1089 1125 0x40 0x5
[   19.443052] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1080": 50 148500 1920 2448 2492 2640 1080 1084 1089 1125 0x40 0x5
[   19.443236] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1080": 30 74250 1920 2008 2052 2200 1080 1084 1089 1125 0x40 0x5
[   19.443424] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1080": 30 74176 1920 2008 2052 2200 1080 1084 1089 1125 0x40 0x5
[   19.443606] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1080": 25 74250 1920 2448 2492 2640 1080 1084 1089 1125 0x40 0x5
[   19.443791] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1080": 24 74250 1920 2558 2602 2750 1080 1084 1089 1125 0x40 0x5
[   19.443991] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1920x1080": 24 74176 1920 2558 2602 2750 1080 1084 1089 1125 0x40 0x5
[   19.444173] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1600x1200": 85 229500 1600 1664 1856 2160 1200 1201 1204 1250 0x40 0x5
[   19.444355] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1600x1200": 75 202500 1600 1664 1856 2160 1200 1201 1204 1250 0x40 0x5
[   19.444543] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1600x1200": 70 189000 1600 1664 1856 2160 1200 1201 1204 1250 0x40 0x5
[   19.444725] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1600x1200": 65 175500 1600 1664 1856 2160 1200 1201 1204 1250 0x40 0x5
[   19.444907] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1600x1200": 60 162000 1600 1664 1856 2160 1200 1201 1204 1250 0x40 0x5
[   19.445093] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1680x1050": 85 214750 1680 1808 1984 2288 1050 1053 1059 1105 0x40 0x6
[   19.445275] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1680x1050": 75 187000 1680 1800 1976 2272 1050 1053 1059 1099 0x40 0x6
[   19.445458] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1680x1050": 60 119000 1680 1728 1760 1840 1050 1053 1059 1080 0x40 0x9
[   19.445644] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1680x945": 60 131481 1680 1784 1960 2240 945 946 949 978 0x0 0x6
[   19.445826] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1400x1050": 85 179500 1400 1504 1656 1912 1050 1053 1057 1105 0x40 0x6
[   19.446009] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1400x1050": 75 156000 1400 1504 1648 1896 1050 1053 1057 1099 0x40 0x6
[   19.446195] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1400x1050": 60 101000 1400 1448 1480 1560 1050 1053 1057 1080 0x40 0x9
[   19.446377] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1600x900": 60 108000 1600 1624 1704 1800 900 901 904 1000 0x40 0x5
[   19.446559] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x1024": 85 157500 1280 1344 1504 1728 1024 1025 1028 1072 0x40 0x5
[   19.446745] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x1024": 75 135000 1280 1296 1440 1688 1024 1025 1028 1066 0x40 0x5
[   19.446928] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x1024": 60 108000 1280 1328 1440 1688 1024 1025 1028 1066 0x40 0x5
[   19.447110] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1440x900": 85 157000 1440 1544 1696 1952 900 903 909 948 0x40 0x6
[   19.447297] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1440x900": 75 136750 1440 1536 1688 1936 900 903 909 942 0x40 0x6
[   19.447480] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1440x900": 60 88750 1440 1488 1520 1600 900 903 909 926 0x40 0x9
[   19.447663] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x960": 85 148500 1280 1344 1504 1728 960 961 964 1011 0x40 0x5
[   19.447848] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x960": 60 108000 1280 1376 1488 1800 960 961 964 1000 0x40 0x5
[   19.448030] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1366x768": 60 85500 1366 1436 1579 1792 768 771 774 798 0x40 0x5
[   19.448212] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1360x768": 60 85500 1360 1424 1536 1792 768 771 777 795 0x40 0x5
[   19.448399] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x800": 85 122500 1280 1360 1496 1712 800 803 809 843 0x40 0x6
[   19.448582] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x800": 75 106500 1280 1360 1488 1696 800 803 809 838 0x40 0x6
[   19.448764] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x800": 60 71000 1280 1328 1360 1440 800 803 809 823 0x40 0x9
[   19.448950] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1152x864": 75 108000 1152 1216 1344 1600 864 865 868 900 0x40 0x5
[   19.449133] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x768": 85 117500 1280 1360 1496 1712 768 771 778 809 0x40 0x6
[   19.449315] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x768": 75 102250 1280 1360 1488 1696 768 771 778 805 0x40 0x6
[   19.449500] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x768": 60 68250 1280 1328 1360 1440 768 771 778 790 0x40 0x9
[   19.449683] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x720": 60 74250 1280 1390 1430 1650 720 725 730 750 0x40 0x5
[   19.449866] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x720": 60 74250 1280 1390 1430 1650 720 725 730 750 0x40 0x5
[   19.450049] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x720": 60 74176 1280 1390 1430 1650 720 725 730 750 0x40 0x5
[   19.450232] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1280x720": 50 74250 1280 1720 1760 1980 720 725 730 750 0x40 0x5
[   19.450415] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1024x768": 85 94500 1024 1072 1168 1376 768 769 772 808 0x40 0x5
[   19.450598] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1024x768": 75 78750 1024 1040 1136 1312 768 769 772 800 0x40 0x5
[   19.450780] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1024x768": 70 75000 1024 1048 1184 1328 768 771 777 806 0x40 0xa
[   19.450962] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1024x768": 60 65000 1024 1048 1184 1344 768 771 777 806 0x40 0xa
[   19.451144] [drm:drm_mode_debug_printmodeline [drm]] Modeline "1024x576": 60 46970 1024 1064 1168 1312 576 577 580 597 0x0 0x6
[   19.451325] [drm:drm_mode_debug_printmodeline [drm]] Modeline "832x624": 75 57284 832 864 928 1152 624 625 628 667 0x40 0xa
[   19.451507] [drm:drm_mode_debug_printmodeline [drm]] Modeline "800x600": 85 56250 800 832 896 1048 600 601 604 631 0x40 0x5
[   19.451689] [drm:drm_mode_debug_printmodeline [drm]] Modeline "800x600": 75 49500 800 816 896 1056 600 601 604 625 0x40 0x5
[   19.451871] [drm:drm_mode_debug_printmodeline [drm]] Modeline "800x600": 72 50000 800 856 976 1040 600 637 643 666 0x40 0x5
[   19.452088] [drm:drm_mode_debug_printmodeline [drm]] Modeline "800x600": 60 40000 800 840 968 1056 600 601 605 628 0x40 0x5
[   19.452277] [drm:drm_mode_debug_printmodeline [drm]] Modeline "800x600": 56 36000 800 824 896 1024 600 601 603 625 0x40 0x5
[   19.452459] [drm:drm_mode_debug_printmodeline [drm]] Modeline "720x576": 50 27000 720 732 796 864 576 581 586 625 0x40 0xa
[   19.452641] [drm:drm_mode_debug_printmodeline [drm]] Modeline "720x576": 50 27000 720 732 796 864 576 581 586 625 0x40 0xa
[   19.452826] [drm:drm_mode_debug_printmodeline [drm]] Modeline "848x480": 60 33750 848 864 976 1088 480 486 494 517 0x40 0x5
[   19.453009] [drm:drm_mode_debug_printmodeline [drm]] Modeline "720x480": 60 27027 720 736 798 858 480 489 495 525 0x40 0xa
[   19.453191] [drm:drm_mode_debug_printmodeline [drm]] Modeline "720x480": 60 27027 720 736 798 858 480 489 495 525 0x40 0xa
[   19.453377] [drm:drm_mode_debug_printmodeline [drm]] Modeline "720x480": 60 27000 720 736 798 858 480 489 495 525 0x40 0xa
[   19.453559] [drm:drm_mode_debug_printmodeline [drm]] Modeline "720x480": 60 27000 720 736 798 858 480 489 495 525 0x40 0xa
[   19.453741] [drm:drm_mode_debug_printmodeline [drm]] Modeline "640x480": 85 36000 640 696 752 832 480 481 484 509 0x40 0xa
[   19.453926] [drm:drm_mode_debug_printmodeline [drm]] Modeline "640x480": 75 31500 640 656 720 840 480 481 484 500 0x40 0xa
[   19.454108] [drm:drm_mode_debug_printmodeline [drm]] Modeline "640x480": 73 31500 640 664 704 832 480 489 492 520 0x40 0xa
[   19.454290] [drm:drm_mode_debug_printmodeline [drm]] Modeline "640x480": 67 30240 640 704 768 864 480 483 486 525 0x40 0xa
[   19.454478] [drm:drm_mode_debug_printmodeline [drm]] Modeline "640x480": 60 25200 640 656 752 800 480 490 492 525 0x40 0xa
[   19.454660] [drm:drm_mode_debug_printmodeline [drm]] Modeline "640x480": 60 25175 640 656 752 800 480 490 492 525 0x40 0xa
[   19.454842] [drm:drm_mode_debug_printmodeline [drm]] Modeline "640x480": 60 25175 640 656 752 800 480 490 492 525 0x40 0xa
[   19.455030] [drm:drm_mode_debug_printmodeline [drm]] Modeline "720x400": 85 35500 720 756 828 936 400 401 404 446 0x40 0x6
[   19.455212] [drm:drm_mode_debug_printmodeline [drm]] Modeline "720x400": 70 28320 720 738 846 900 400 412 414 449 0x40 0x6
[   19.455394] [drm:drm_mode_debug_printmodeline [drm]] Modeline "640x400": 85 31500 640 672 736 832 400 401 404 445 0x40 0x6
[   19.455577] [drm:drm_mode_debug_printmodeline [drm]] Modeline "640x350": 85 31500 640 672 736 832 350 382 385 445 0x40 0x9
So you have 4 modes rejected because they are only supported as yuv4:2:0
Sorry, your monitor onlyl supports 4k60 in a mode that the Pi can't generate.
I can see this being another "HD Ready" saga over the difference between accepting 1080p but only being a 720p panel.
tinyker
Fri Mar 27, 2020 2:15 am
Noted
Thanks for analysing the EDID.
I have sent an email to the manufacturer to make sure this is the case. It would be a shame to have to build a computer just to drive this projector and having to put the RPi away.
Is the data formatting a hardware limitation? or is it a software limitation?
Fri Mar 27, 2020 8:16 am
What's wrong with 30 fps?
“My wife said to me `...you’re not even listening`.
I thought, that’s an odd way to start a conversation.."
6by9
Fri Mar 27, 2020 10:29 am
Hardware.
YUV4:2:0 requires chroma subsampling after composition. I'm not even sure exactly how it is packed into the HDMI signal as lines will vary in length depending on whether they have a chroma line or not.
4:2:2 can be supported as it only requires horizontal subsampling, so every output line is the same.
tinyker
Sat Apr 18, 2020 1:22 am
Bad news from Viewsonic. The projector only supports [email protected] using YUV 4:2:0. Game over.
jamesh wrote:What's wrong with 30 fps?
Nothing inherently wrong. The hardware is capable of 60Hz (if they could both use the same format) so who would not want to run it at full speed? 30 Hz is fine for watching videos. For the rest it's not that great.
Hardware.
Thanks for the info and support! A hardware limitation is like a brick wall in this case. At least I got closure on the topic and it may hopefully help others that are facing the same issue if they find this thread.
