alan31337
Re: Imager says "error writing to storage (while flushing)"
Fri May 22, 2020 12:03 am
I have been experiencing this problem today and wanted to share how I resolved it in case it helps.
The issue in my instance was due to Windows 10 Controlled Folder Access.
Screen snip here showing relevant log entry:
https://imgur.com/a/EU7Al5f
To view Protection History
Follow these steps to identify if you have a matching Protection History entry to the one I have shown above.
  • Press the Start button.
  • Type controlled folder access, press Enter.
  • You should the Ransomware Protection window appear, example: https://imgur.com/a/zJan0Di
  • From this window, click block history
  • The Protection History window will open, the relevant entry will likely be the most recent at the top.
To resolve issue:
From the relevant entry in the Protection History window, select "Actions: Allow on device" and then attempt the SD Card write again.
if this is the cause of your issue, the write should succeed.
pucky_wins
Fri Jul 03, 2020 1:52 pm
I threw away a perfectly good sdcard because of this bug. Thanks for that...
incognitum
Sun Jul 05, 2020 6:48 pm
An interesting thing is that Microsoft apparently has a default whitelist of applications that do should be allowed to write without manual action:
"Apps determined by Microsoft as friendly are always allowed"
Wonder what the criteria for being put on the list are.
