john_alan
rpi-eeprom-update on the Pi4 - unusual output?
Thu Feb 27, 2020 7:06 pm
BCM2711 detected
BOOTLOADER: up-to-date
CURRENT: Thu Jan  9 18:25:54 UTC 2020 (1578594354)
 LATEST: Tue Sep 10 10:41:50 UTC 2019 (1568112110)
VL805: up-to-date
CURRENT: 000137ad
 LATEST: 000137ad
I see the above, running sudo
rpi-eeprom-update
on my Pi4, why would current be greater than latest?
Do I need to clear some cache?
John
Solskogen
Re: rpi-eeprom-update on the Pi4 - unusual output?
Fri Feb 28, 2020 2:29 pm
New install with a old image, perhaps? Try a "apt-get update && apt-get dist-upgrade -fu && reboot" and try again.
timg236
Fri Feb 28, 2020 2:59 pm
It looks like a beta image was installed on that board at some point in the past but the /etc/default/rpi-eeprom-update is pointing at the 'critical' release folder instead
john_alan
Sat Feb 29, 2020 7:52 am
thanks @timg236 - what can I do to get this board to the right version?
PeterO
Sat Feb 29, 2020 8:02 pm
I get the same output so I too would like to know if it is a problem , and if so how to fix it.
PeterO
RonR
Sat Feb 29, 2020 11:07 pm
How 'bout this instead?:
root@FreePBX:~# rpi-eeprom-update
BCM2711 detected
CURRENT: Fri 17 Jan 17:37:11 UTC 2020 (1579282631)
 LATEST: Tue 10 Sep 10:41:50 UTC 2019 (1568112110)
VL805: up-to-date
CURRENT: 000137ad
 LATEST: 000137ad
PeterO
Sun Mar 01, 2020 8:04 am
pi@raspberrypi:/etc/default $ cat rpi-eeprom-update
FIRMWARE_RELEASE_STATUS="critical"
So what should it say ?
PeterO
DirkS
Sun Mar 01, 2020 11:43 am
PeterO
Mine says
FIRMWARE_RELEASE_STATUS=beta
and seems to be ok
pi@raspiserver:~$ sudo rpi-eeprom-update
BCM2711 detected
 LATEST: Fri 17 Jan 17:37:11 UTC 2020 (1579282631)
VL805: up-to-date
CURRENT: 000137ad
 LATEST: 000137ad
PeterO
Mon Mar 02, 2020 10:01 am
It seems unlikely it should "beta" or "critical" ?
Can anyone explain what these mean and what it should say ?
PeterO
andrum99
Mon Mar 02, 2020 1:08 pm
PeterO
'Current' shows the bootloader and VL805 firmware that are currently installed in the EEPROM chips on that Pi. 'Latest' shows the newest firmware on the branch you have selected: 'critical' is the default. There are also 'beta' and now 'stable' branches. You select which branch to install by setting the FIRMWARE_RELEASE_STATUS variable in the file '/etc/default/rpi-eeprom-update'.
If you previously chose the 'beta' branch, then changed back to 'critical' then this would explain why 'current' is later than 'latest' - the 'beta' branch was updated more recently.
If you have never changed the value of FIRMWARE_RELEASE_STATUS, and 'current' is newer than 'latest' then that's a bug.
