sorbiegunner
confusing hostnames and ip addresses
Tue Feb 25, 2020 4:11 pm
I renamed my Pi4 to raspberrypi4.
If I connect to my lan using wifi the hostname is given as RASPBERRYPI4 and an IP address is assigned.
If I connect to my lan using a network cable the hostname is as RASPBERRYPI and a different IP address is assigned but the wifi ip address is removed. Internet connection works when connected to wifi but doesn't work when the ethernet cable is plugged in.
These are the hostnames given in the router interface not on the raspberry pi device configuration dialog which stays at raspberrypi4.
I am using the Pi as a plex server so obviously an ethernet connection would be preferable to wifi.
epoch1970
Re: confusing hostnames and ip addresses
Tue Feb 25, 2020 6:55 pm
Try rebooting the Pi and the router. Changing hostname is not supposed to happen often, processes may have cached the old host name.
