[SOLVED] Raspberry doesn't save my modifications
Posted: Tue Feb 25, 2020 3:59 pm
I have a "little" problem since this morning, all I've done has been cancelled... I didn't understand until I tried a simple "touch test".
The file is created, i can do everything I want : modify, rename, delete... etc.
Life seems good... until I reboot.
My file has disappeared, all I have installed too, all I have deleted is back etc...
FS seems to be readonly since I've tried to disable IPv6.
all I've done is follow this instruction :
It worked but since this modification, no more modification can be done.. so I've removed this part from cmdline successfully but without any effect.
This is a fresh install I did yesterday, so no data to loose, but I prefer understand.
Raspbian 10 lite
Add ipv6.disable=1 to cmdline.txtThis is a fresh install I did yesterday, so no data to loose, but I prefer understand.
Raspbian 10 lite
