hughparker1
Raspbian update: getting notification 'buster InRelease' doesn't support architecture 'i386'
Sun Feb 23, 2020 5:07 pm
hi, I have a raspberry Pi4 running the recommended Raspbian downloaded from the website. When I run update, I am getting a notification that says 'buster InRelease' doesn't support architecture 'i386'
here is the output for the update command...
[email protected]:~ $ sudo apt update
Get:1 http://archive.raspberrypi.org/debian buster InRelease [25.1 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Get:3 http://archive.raspberrypi.org/debian buster/main armhf Packages [277 kB]
Get:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
Get:5 http://archive.raspberrypi.org/debian buster/main i386 Packages [166 kB]
Fetched 13.5 MB in 22s (606 kB/s)
Reading package lists... Done
Building dependency tree
83 packages can be upgraded. Run 'apt list --upgradable' to see them.
N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' doesn't support architecture 'i386'
N: Skipping acquire of configured file 'contrib/binary-i386/Packages' as repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' doesn't support architecture 'i386'
N: Skipping acquire of configured file 'non-free/binary-i386/Packages' as repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' doesn't support architecture 'i386'
N: Skipping acquire of configured file 'rpi/binary-i386/Packages' as repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' doesn't support architecture 'i386'
I saw some hits on 'askubuntu.com/questions' they suggest to change my sources.list, adding '[arch=amd64]' to each line with the error.
https://askubuntu.com/questions/1029198 ... ry#1029865
e.g....
deb [arch=amd64] https://download.virtualbox.org/virtualbox/debian bionic contrib
but the issue they are trying to fix is not the same as my situation, similar but not exactly the same.
this is what my sources.list looks like at moment...
[email protected]:/ $ cat /etc/apt/sources.list
deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
[email protected]:/ $ cat /etc/apt/sources.list.d/raspi.list
deb http://archive.raspberrypi.org/debian/ buster main
#deb-src http://archive.raspberrypi.org/debian/ buster main
I don't want to make any changes that might break my setup, I have used Linux for a while now but I'm no expert. any advice would be appreciated.
Re: Raspbian update: getting notification 'buster InRelease' doesn't support architecture 'i386'
Sun Feb 23, 2020 5:17 pm
That is correct. The Pi is an ARM based device, not an x86 system.
They are wrong. The Pi is still an ARM based system. It is not an "amd64" (AKA x86-64) system.
It sounds like you've already done that. What changes did you make to your sources.list files and what software were you trying to install?
Which instructions were you originally following?
Unreadable squiggle
B.Goode
Sun Feb 23, 2020 5:24 pm
Who or what was responsible for the inappropriate
Do you have any other entries in /etc/apt/sources.list.d/
hughparker1
Sun Feb 23, 2020 5:39 pm
I haven't touched my sources list, it is as originally installed. I just wanted to get some advice / guidance.
EDIT:
[/quote]
[/quote]
i wasn't installing any software, I wasn't following any instructions... I was just running update
hughparker1
Sun Feb 23, 2020 5:41 pm
No other entries, I just copy'n'paste the only entry that was there.
EDIT:
i haven't made any changes in sources.list since installation.
B.Goode
Sun Feb 23, 2020 5:42 pm
In that case there might be a suspicion that something outside your control has broken.
In which case doing nothing other than retrying later will be the best approach...
hughparker1
Sun Feb 23, 2020 5:54 pm
jojopi wrote:
Sun Feb 23, 2020 5:30 pm
Try:
sudo dpkg --remove-architecture i386
thanks for suggestion. can you advise what this command will change in my system? just curious.
jojopi
Sun Feb 23, 2020 6:22 pm
The corresponding --add-architecture i386 tells the package management system that you want to be able to install foreign i386 packages alongside native armhf packages, using Debian/Raspbian Multiarch. When I do that, I get very similar errors to those in the first post, and when I remove the architecture again, they go away.
In any case, the command is safe. If you run it on an unbroken Raspbian system it says dpkg: warning: cannot remove non-foreign architecture 'i386'. If you run it on a working Multiarch system it says dpkg: error: cannot remove architecture 'i386' currently in use by the database. If you run it on a native i386 system it says dpkg: warning: cannot remove non-foreign architecture 'i386'. It will not uninstall any packages, and you can always revert it with --add-architecture.
Do you really not remember doing anything that mentioned i386 in the past?
Sun Feb 23, 2020 7:07 pm
Try
dpkg --print-architecture
On a clean Pi running Raspbian that should show only "armhf". If it doesn't and you really haven't installed anything using a non-standard method, then your Pi has likely been compromised as others have already said.
Unreadable squiggle
jojopi
Sun Feb 23, 2020 7:19 pm
That just prints the native architecture. You would need --print-foreign-architectures to see if i386 had been added.
hughparker1
Sun Feb 23, 2020 8:28 pm
thanks @jojopi for your explanation.
I don't remember doing anything that mentioned i386 in the past. I always take notes of any config changes and and I have found nothing that might have caused any problems, here is an extract of my previous notes relating to any changes I made in the past, in case there was something that cause this issue....
.......................................... begin log ............................................
02/01/2020
https://www.raspberrypi.org/documentati ... teeprom.md
[email protected]:~ $ sudo apt full-upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[email protected]:~ $ sudo apt install rpi-eeprom
rpi-eeprom is already the newest version (2.4-1).
[email protected]:~ $ sudo rpi-eeprom-update
BOOTLOADER: up-to-date
CURRENT: Tue 10 Sep 2019 10:41:50 AM UTC (1568112110)
 LATEST: Tue 10 Sep 2019 10:41:50 AM UTC (1568112110)
VL805: up-to-date
CURRENT: 000137ab
 LATEST: 000137ab
[email protected]
[email protected]:~ $ vcgencmd bootloader_config
BOOT_UART=0
WAKE_ON_GPIO=1
POWER_OFF_ON_HALT=0
[email protected]:~ $ vcgencmd bootloader_version
Sep 10 2019 10:41:50
version f626c772b15ba1b7e0532a8d50a761b3ccbdf3bb (release)
timestamp 1568112110
02/01/2020
Setting the screen saver/screen blanking...
https://www.raspberrypi.org/documentati ... ensaver.md
On the Console # this doesn't apply to me
If you are using the Raspberry Pi solely on the console (no desktop GUI), you need to set the console blanking. The current setting, in seconds, can be displayed using
$ cat /sys/module/kernel/parameters/consoleblank
Here, consoleblank is a kernel parameter. In order to be permanently set, it needs to be defined on the kernel command line.
$ sudo nano /boot/cmdline.txt
Add consoleblank=0 to turn screen blanking off completely, or edit it to set the number of seconds of inactivity before the console will blank. Note the kernel command line must be a single line of text.
On the Raspberry Pi Desktop # I will follow these instructions
By default, the Raspberry Pi Desktop does not have any easy-to-use screensaver software installed, although the screensaver is enabled. Firstly, you should install the X Windows screensaver application.
$ sudo apt install xscreensaver
This may take a few minutes.
Once this has been installed, you can find the screensaver application under the Preferences option on the main desktop menu. This provides many options for setting up the screensaver, or disabling it completely.
reboot and screen saver now works!
.................................. end of log ................................
the above is the only change I have made since installing Raspbian
Try:
I ran the command and then 'update' and it completed with no notification messages. great result! here is the output...
[email protected]:/ $ sudo dpkg --remove-architecture i386
[email protected]:/ $ sudo apt update
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Get:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
Fetched 13.0 MB in 17s (785 kB/s)
87 packages can be upgraded. Run 'apt list --upgradable' to see them.
I'm glad it worked out OK. Thanks again for your help, much appreciated.
Mon Feb 24, 2020 5:50 am
It is still worrying that this happened in the first place. If you did not add the i386 architecture, who did and how?
Do you connect to the internet through a router or directly?
Did you change the default "pi" password from "raspberry" to something else immediately?
Unreadable squiggle
hughparker1
Mon Feb 24, 2020 7:14 am
I connect to internet via wireless router.
I haven't changed password from default.
I did notice that when I run update command I am not prompted for a password.
I thought this was unusual as I am always prompted for a password on other Linux distributions.
Mon Feb 24, 2020 9:17 am
sudo give you elevated privileges, it is extremely common in Linux:
https://linux.die.net/man/8/sudo
https://www.raspberrypi.org/documentati ... pdating.md
joan
Mon Feb 24, 2020 9:23 am
If you didn't add the 386 architecture it follows someone else did. Given that you don't know what else they did the only safe thing to do is to start from scratch with a fresh image. Perhaps this time set a new password before connecting to the internet.
hughparker1
Mon Feb 24, 2020 10:13 am
I think you are right, I will start from scratch and create new password.
Thanks to everyone for quick responses to my issue, much appreciated.
plugwash
Thu Mar 05, 2020 3:41 pm
Someone or something.
There are lots of software installation scripts out there intended for debian/ubuntu amd64 systems that will add i386 as a foreign architecture.
