BrokenLumber
hostapd problems while setting up Pi 4 as Access Point
Sun Feb 23, 2020 5:02 pm
First of all i want to say that i'm new to all of this, so please dont hate me if the answer to my problem seemed obvious to you.
I just tried to follow this tutorial to set up my Pi 4 as an Access Point.
I follows all the steps, but i got stuck after "Configuring the access point host software (hostapd)"
When i try to start hostapd i get the following massage:
Job for hostapd.service failed because the control process exited with error code.
See "systemctl status hostapd.service" and "journalctl -xe" for details.
when i then use the systemctl status hostapd.service command i get this:
● hostapd.service - Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
   Loaded: loaded (/lib/systemd/system/hostapd.service; enabled; vendor preset: enabled)
   Active: activating (auto-restart) (Result: exit-code) since Sun 2020-02-23 17:56:22 CET; 333ms ago
  Process: 2101 ExecStart=/usr/sbin/hostapd -B -P /run/hostapd.pid -B $DAEMON_OPTS ${DAEMON_CONF} (code=exited, status=1
when i use journalctl -xe i get the following:
Feb 23 17:57:36 raspberrypi hostapd[2159]: wlan0: AP-DISABLED
Feb 23 17:57:36 raspberrypi hostapd[2159]: wlan0: Unable to setup interface.
Feb 23 17:57:36 raspberrypi hostapd[2159]: wlan0: interface state DISABLED->DISABLED
Feb 23 17:57:36 raspberrypi hostapd[2159]: wlan0: CTRL-EVENT-TERMINATING
Feb 23 17:57:36 raspberrypi hostapd[2159]: hostapd_free_hapd_data: Interface wlan0 wasn't started
Feb 23 17:57:36 raspberrypi hostapd[2159]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Feb 23 17:57:36 raspberrypi systemd[1]: hostapd.service: Control process exited, code=exited, status=1/FAILURE
-- Subject: Unit process exited
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- An ExecStart= process belonging to unit hostapd.service has exited.
-- The process' exit code is 'exited' and its exit status is 1.
Feb 23 17:57:36 raspberrypi systemd[1]: hostapd.service: Failed with result 'exit-code'.
-- Subject: Unit failed
-- The unit hostapd.service has entered the 'failed' state with result 'exit-code'.
Feb 23 17:57:36 raspberrypi systemd[1]: Failed to start Advanced IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator.
-- Subject: A start job for unit hostapd.service has failed
-- A start job for unit hostapd.service has finished with a failure.
-- The job identifier is 32180 and the job result is failed.
Now, like i said, im a total noob. I'm trying to learn all of this, but i din't find anything about this problem.
Ps: I have OMV installed, could that somehow be the problem or be connected to the problem?
If yes, how do i create an AP while still using OMV?
epoch1970
Re: hostapd problems while setting up Pi 4 as Access Point
Sun Feb 23, 2020 6:13 pm
This tutorial is designed to work with Raspbian Buster. Nothing says it would work on an other OS.
BrokenLumber
Sun Feb 23, 2020 6:23 pm
I am using the newest version Raspbian Buster Lite.
