rpi4 usb issue
Posted: Sat Feb 22, 2020 7:33 am
by ilvalle
Hi all, I've just switch from rpi2 to rpi4.
As before a wifi usb dongle and a usb hdd is connected to the new rpi, the hdd has its own power supply. As soon as I access the hdd through the wifi, the rpi crash. I don't have any log because the rpi is headless.
what am I missing? is it a kernel issue? something like https://github.com/raspberrypi/firmware/issues/1333?
Is there any option to add to /etc/config.txt ?
I'm running latest kernel.
regards
Re: rpi4 usb issue
Posted: Sat Feb 22, 2020 5:26 pm
by epoch1970
Connect via ssh in a separate window and run "tail -F /var/log/syslog" on the Pi.
Then access the drive.
Normally you'll see a trace of the crash.
Re: rpi4 usb issue
Posted: Sat Feb 22, 2020 7:58 pm
by ilvalle
I've tried but nothing. I've also tried from an other host connected via ethernet
Re: rpi4 usb issue
Posted: Sat Feb 22, 2020 8:54 pm
by HawaiianPi
As before a wifi usb dongle...
The Pi 4B has built-in WiFi, so why are you using a USB dongle?
What are you using for the Pi4 power supply?
Is it a USB 3.0 HDD, and is the WiFi dongle 2.4GHz?
Re: rpi4 usb issue
Posted: Sat Feb 22, 2020 9:19 pm
by jamesh
That sounds like a power supply problem.
Re: rpi4 usb issue
Posted: Sat Feb 22, 2020 9:36 pm
by ilvalle
Hi there, the power supply is the official one. The built in wifi has no external antenna and is slower.
The crash is not always as soon as the hdd starts, sometimes it happens after few minutes.
Re: rpi4 usb issue
Posted: Mon Feb 24, 2020 5:57 pm
by ilvalle
To save some power I run switched the hdmi off with the command below without any better result
/opt/vc/bin/tvservice -off
Re: rpi4 usb issue
Posted: Tue Feb 25, 2020 2:10 pm
by sora03
can you do a lsusb to determine what is the manufacturer of the usb hdd?
I have a problem but it may or not be related, in my case I encounter a USB overcurrent change error in dmesg which causes the PI to disconnect the HDD and causing I/O errors. Since you have an externally powered HDD, it may not be the issue.
I would try to do the following (save power):
- underclock CPU/GPU
- disable bluetooth via config.txt
- tvservice -o (already done)
To try to detect the issue further:
- stress test the pi using stress-ng
- monitor vcgencmd get_throttled
- do an intensive I/O operations (copy, read)
Pi 4 should not have USB bandwidth issues, in my case Pi2B and Pi3B+ has the USB bandwidth problems when connecting too many USB devices or I/O intensive devices.
Re: rpi4 usb issue
Posted: Tue Feb 25, 2020 3:56 pm
by ilvalle
Hi sora03,
the same configuration worked with a rpi2 device.
Below few relevant settings I configured
/boot/config.txt
# Disable the PWR LED
dtparam=pwr_led_trigger=none
dtparam=pwr_led_activelow=off
# Disable the Activity LED
dtparam=act_led_trigger=none
dtparam=act_led_activelow=off
#Disable bluetooth & wifi
dtoverlay=disable-bt
dtoverlay=disable-wifi
rc.local
echo none > /sys/class/leds/led1/trigger
echo none >  /sys/class/leds/ath9k_htc-phy0/trigger
hdparm -B127 /dev/sda
echo "powersave" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
lsusb
Bus 002 Device 002: ID 1234:5678 Brain Actuated Technologies
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 0cf3:9271 Qualcomm Atheros Communications AR9271 802.11n
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
/etc/modprobe.d/ath9k.conf
options ath9k_htc nohwcrypt=1 ps_enable=0 btcoex_enable=0 blink=0
The hdd is this one https://www.amazon.it/Raidsonic-Sistema ... 882&sr=8-6
Re: rpi4 usb issue
Posted: Thu Feb 27, 2020 2:35 pm
by sora03
Are you sure that the command suggested by epoch1970 does not yield results?
This command specifically:
On your PC open an SSH session to your pi and execute this command,, so we can trace the Pi crash:
sudo tail -F /var/log/messages
This command will stream dmesg until you encounter your problem, it will log the last message including the error. Like a blackbox of an airplane (I may have exaggerated).
Can you also post the dmesg log of your Pi, since you are using a VIA Labs USB to SATA are not having problems with usb quirks?
Can you try to underclock the Pi using /boot/config.txt to check if it still crashes.
arm_freq=1000
arm_freq_min=100
Do you have watchdog installed?
Can you try to use the Pi without HDD just the built in microSD card?
Is it when you do an intensive input/output operations does the pi crash? (eg. writing large files/copying large files)
I do not know what does hdparm -B27 command does, perhaps spinning disk down or up may cause a problem.
Check all of your USB cables.
Re: rpi4 usb issue
Posted: Thu Feb 27, 2020 6:52 pm
by ilvalle
Hi, I'm sure no message from ssh before the crash. Tested a couple of times with a pc connected via eth0.
spinning down the hdd is necessary during the day, the night and all those hours when no one is at home.
Accessing the hdd via eth0 works without issue, ~30MB/s.
I haven't tested to underclock the pi, although setting the scaling_governor to powersave block the frequency at 600Mhz.
Yes, the crash happen when there is input/output traffic, most of the times when the phone sends the new file/photo to the rpi to be saved in the hdd.
Re: rpi4 usb issue
Posted: Fri Feb 28, 2020 12:11 am
by sora03
Try to also change the governor to conserve instead of powersave. I've had problems with high I/O disconnecting my USB HDD but this was fixed by using an external powered hub, (in my case).
Re: rpi4 usb issue
Posted: Sat Feb 29, 2020 2:33 am
by Eng
I have a similar problem before and I spent a lot of time before I found a solution to this problem, try to add this line to `config.txt`:
over_voltage=1
Please, check and let me know is it works for you or not.
Re: rpi4 usb issue
Posted: Sat Feb 29, 2020 7:31 am
by ilvalle
Hi @sora03. I moved the HDD to the usb2 port and switched to conservative the scaling governor. The rpi crashed after few minutes, before was crashing after few seconds.
