dukedude
Raspberry Pi 4b is not booting after rpi-update.
Tue Feb 11, 2020 6:32 am
I have an issue with raspberry pi 4b after rpi-update yesterday.
I have checked below link but the problem still exists. Nothing changed.
https://www.raspberrypi.org/forums/view ... hp?t=38325
My Pi hangs after "random: crng init done".
I have added initcall_debug=1 to my cmdline.txt. "random: crng init done" disappeared but boot hangs out on:
probe of 1-1.4 returned after 183354 usecs
Imperf3kt
Re: Raspberry Pi 4b is not booting after rpi-update.
Tue Feb 11, 2020 7:45 am
rpi-update comes with a warning that it can ruin your system and cause it to not boot, among other things.
If I may, why did you;
a) think you needed rpi-update
B) not read the warning
To fix your Pi, you need to reflash the SD card or restore a backup if you have one.
The recommended update method is via
sudo apt update
sudo apt full-upgrade
55:55:44:44:4C
52:4C:52:42:41
timg236
Tue Feb 11, 2020 7:49 am
It might be worth trying over_voltage=1 in config.txt and removing any over clocking settings
omicron01
Tue Feb 11, 2020 8:39 am
Hello together,
I have the same issue as dukedude since yesterday evening (2020-02-10) after I upgraded the System (running Buster Lite Image from 2019-09-26) with
sudo apt-get update && sudo apt-get upgrade
I don´t run RPI-Update or things like that.
After that I flashed a new SD (because I had no time to search for errors :roll:) with the newest Rasbian Image from 2020-02-05 (with Desktop, but without "recommended Software). After I configured my Raspi with
sudo raspi-config
and after the final reboot the same issue occurred.
But I started raspi-config mutliple times to configure Localization, SSH, VNC etc. and I reboot also multible times between these steps without any issue.
I believe my last step in raspi-config was to configure the raspi to "Wait for Network after reboot". And after this final reboot the System is not longer reachable.
I am not at home, so its not possible for me to look on a physical display. For now SSH should be my single way to my Raspi :(
My IP Configuration is static and I don´t use DHCP.
The System runs prior this issue for weeks very stable without any issues or errors. I don´t use overclocking settings or other things like that.
I hope this helps to figure out the issue.
Regards, Omicron01
dukedude
Tue Feb 11, 2020 8:58 am
sudo apt update
Fine, I didn't know that we can't update when we want to do it: rpi-update anytime. Now I know that there is something wrong.
BTW. I have refleshed the SD card, but after that when I setup my password and language, restarting there is an another issue:
bcm2835-clk fe101000.cprman: plla couldn' lock PLL
I thinks that is something connected to language. I see this one first time. I have raspberry pi 4 b more than 6 months.
dukedude
Tue Feb 11, 2020 8:59 am
Maybe I do this next time. It's too late now because I have refleshed my sd card.
Tue Feb 11, 2020 9:35 am
sudo apt update
https://www.raspberrypi.org/documentati ... pdating.md
Retired disgracefully.....
dukedude
Tue Feb 11, 2020 12:29 pm
sudo apt update
Could you explain what you are talking about? It doesn't help me anyway.
Tue Feb 11, 2020 12:46 pm
It does not state anywhere to use rpi-update, so you need to undo the changes :?
Tue Feb 11, 2020 12:51 pm
We are currently looking in to some boot issues that have suddenly started appearing.
dukedude
Tue Feb 11, 2020 12:54 pm
I can't undo the changes. I need a patch or a previous image.
dukedude
Tue Feb 11, 2020 12:55 pm
If you are working on a solution could you share a previous image?
dukedude
Tue Feb 11, 2020 1:03 pm
I didn't skip a network configuration. It works.
omicron01
Tue Feb 11, 2020 1:40 pm
Hi dukedude,
you did or you did not skip the network setting?
Please discribe what exactly you have done or you have not done.
Thanks in advance...
thezedt
Tue Feb 11, 2020 4:14 pm
For anyone having a non-bootable Pi4 after a simple apt-get upgrade with:
Restoring the kernel/firmware files to a previous build allows the system to boot again.
I'm not sure which file is actually responsible, but since most of the files on the /boot (FAT) partition were modified by the update, I'd restore them all. :roll:
The files from the Jan 6 commit appear to work: https://github.com/raspberrypi/firmware ... 60d80/boot
One is glad to be of service
dukedude
Tue Feb 11, 2020 6:53 pm
Hi dukedude,
did not skip
lol
