HvdW
Lost: Change keyboard layout
Sun Feb 09, 2020 12:50 pm
I crippled my RPI install. (on RPI 3+)
I don't know how, but the result is that when I connect through PuTTY the lines in Raspi-Config and in mc are displayed as signs, like + and others.
When I open rasp-config and goto localiasation I can set language and timezone.
Changing keyboard layout gives strange output:
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = (unset),
        LC_ALL = "en_GB.UTF-8",
        LANG = "en_GB.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_CTYPE to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_MESSAGES to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_ALL to default locale: No such file or directory
Generating locales (this might take a while)...
  en_GB.UTF-8... done
Generation complete.
or
Reloading keymap. This may take a short while
I don't get the chance to change keyboard layout.
Maybe I erased something? But what? How can I restore this.
This failure of displaying lines wouldn't be a big problem, hoever I have installed pivpn with WireGuard and now the QR code doesn't display as such.
Help is appreciated.
PS
I did the buster install on my old RPI B as well to test and there everything displays just fine.
PPS
The output of locale :
LANG=en_GB.UTF-8
LANGUAGE=
LC_CTYPE="en_GB.UTF-8"
LC_NUMERIC="en_GB.UTF-8"
LC_TIME="en_GB.UTF-8"
LC_COLLATE="en_GB.UTF-8"
LC_MONETARY="en_GB.UTF-8"
LC_MESSAGES="en_GB.UTF-8"
LC_PAPER="en_GB.UTF-8"
LC_NAME="en_GB.UTF-8"
LC_ADDRESS="en_GB.UTF-8"
LC_TELEPHONE="en_GB.UTF-8"
LC_MEASUREMENT="en_GB.UTF-8"
LC_IDENTIFICATION="en_GB.UTF-8"
LC_ALL=en_GB.UTF-8
The contents of /etc/default/locale:
#  File generated by update-locale
LANG=en_GB.UTF-8
The contencts of /etc/default/keyboard:
# KEYBOARD CONFIGURATION FILE
# Consult the keyboard(5) manual page.
XKBMODEL="pc105"
XKBLAYOUT="us"
XKBVARIANT=""
XKBOPTIONS=""
BACKSPACE="guess"
Running the option Change WiFi country results in:
Could not communicate with wpa_supplicant
I tried export LC_ALL=en_GB.UTF-8 which resulted in a locale display like:
LANG=en_GB.UTF-8
LANGUAGE=en_GB.UTF-8
LC_ALL=en_GB.UTF-8
Watch the missing " " on some lines.
Who knows knows
Who doesn't doesn't
jojopi
Re: Lost: Change keyboard layout
Sun Feb 09, 2020 7:16 pm
LANGUAGE = (unset),
Those settings are valid. Rather than debug why the locale is selected but not generated, I suggest installing the locales-all package. This trades some disk space for making all locales work without generation:
sudo apt update
sudo apt install locales-all
Fix locale first. Check that PuTTY is set to UTF-8 for remote character set, and to "Use Unicode line drawing code points". If this does not solve the problem, it would help to show us exactly what the lines and QR codes are looking like.
Did you see my reply in the other thread? You do not have a USB keyboard plugged into the Pi (or dpkg-reconfigure thinks you do not). PuTTY sends ASCII/Unicode character numbers, not keyboard codes, so the keyboard setting is irrelevant in that case.
I do not know about WiFi, sorry.
HvdW
Sun Feb 09, 2020 11:06 pm
Solution found!
Shame on me!
From Lubuntu everything's fine, not from W10
Conclusion: it's me and not RPI
Then I deleted the PuTTY profile and created a new profile.
Connected: SUCCESS!
Anyway, thank you very much for assisting.
Here is a view like it was on my RPI 3+ (left) and RPI B (right)
The QR looked like this and is now back to normal.
Who knows knows
Who doesn't doesn't
