KingDariush
Mistakenly moved system folders in Raspbian Buster. System failure
Sat Feb 08, 2020 2:19 pm
I was working on OpenVpn connection settings. Mistakenly I moved system folders in Raspbian Buster by:
sudo mv -r /* /etc/openvpn
Now, raspberry pi isn't boot. How to edit partition or restore?
tpyo kingg
Re: Mistakenly moved system folders in Raspbian Buster. System failure
Sat Feb 08, 2020 2:20 pm
At that point it is a matter of reinstallation and then restoring from backup.
jojopi
Sat Feb 08, 2020 3:10 pm
mv does not accept the -r option. It is always recursive because there is no way to move a directory without the contents also moving.
Assuming you mean "mv /* /etc/openvpn/", that is easy to undo if you have root access to another Linux machine. Otherwise install a new Raspbian image on a spare card, and mount the original card in a USB card reader.
sudo mount /dev/sdX2 /mnt
sudo mv /mnt/etc/openvpn/*/ /mnt/
ejolson
Sat Feb 08, 2020 3:37 pm
That should recover it. There was a thread not too long ago on the dangers and benefits of passwordless sudo. The present thread would serve nicely as an example of one of the dangers.
KingDariush
Sat Feb 08, 2020 4:12 pm
Thanks guys, I'm installing Raspbian Lite. Will let you know after mounting and moving folders back.
