Captain_Harlock
Incorrect Password ssh??
Fri Dec 21, 2012 4:05 pm
Hello All
I have installed Occidentalis v0.2 in an SD and fired up the Raspberry pi. I have not
made any further configurations since the keyboard i have is not recognized.
Thus i have decided to run the device headless.
However when i try to connect through ssh (putty from Windows) in order to run the initial
configuration i am asked for a username/password.
I give as you propose username:pi and password:raspberry
and i get "Access Denied".
Do you have any idea what it may goes wrong?
malakai
Re: Incorrect Password ssh??
Fri Dec 21, 2012 4:20 pm
After receiving the "Access denied" message, hold Ctrl and right-click on the PuTTY window, then select Event log. At the bottom you will see what exactly caused the failure.
Is it prompting you for a password 3 times?
It could be the user does not have rights for ssh access
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
Captain_Harlock
Fri Dec 21, 2012 4:56 pm
Hi i get the following
2012-12-21 18:53:50 Doing Diffie-Hellman key exchange with hash SHA-256
2012-12-21 18:53:51 Host key fingerprint is:
2012-12-21 18:53:51 ssh-rsa 2048 48:c9:b5:1a:9d:1b:35:a5:bd:46:78:85:4c:fd:60:ae
2012-12-21 18:53:51 Initialised AES-256 SDCTR client->server encryption
2012-12-21 18:53:51 Initialised HMAC-SHA1 client->server MAC algorithm
2012-12-21 18:53:51 Initialised AES-256 SDCTR server->client encryption
2012-12-21 18:53:51 Initialised HMAC-SHA1 server->client MAC algorithm
2012-12-21 18:54:28 Attempting keyboard-interactive authentication
2012-12-21 18:54:28 Server refused keyboard-interactive authentication
2012-12-21 18:54:33 Sent password
2012-12-21 18:54:33 Password authentication failed
I use the putty and the username:pi and password:raspberry.
However as i have said above just installed the OS in the SD and booted for the first time. No other configurations, nothing
redhawk
Fri Dec 21, 2012 5:00 pm
Does Occidentalis have a 'pi' user account, perhaps you need root instead??
Richard S.
Captain_Harlock
Fri Dec 21, 2012 5:09 pm
Same results with the official OS. Have tried both.
malakai
Fri Dec 21, 2012 5:20 pm
Did you run sudo raspi-config and enable ssh? Just a shot in the dark on that otherwise try typing the password first just to make sure the keys are mapped correctly delete what you type then go with pi and password.
Captain_Harlock
Fri Dec 21, 2012 5:23 pm
I cannot run the raspi-config because the three keyboards i have tried do not work even with a powered hub! That's why as a last resort try to connect through ssh. The SD contains a fresh install of the latest official raspberry pi OS.
In order to overcome this issue i am trying to connect to the raspberry pi str8 from the putty.
Thus i am prompt for a username/password and i provide the pi/raspberry with no successful results.
Captain_Harlock
Fri Dec 21, 2012 8:44 pm
Please help. Thank you in Advance.
Captain_Harlock
Sun Dec 23, 2012 10:08 pm
Problem solved.
I have replaced the usb power cable and the keyboard was detected successfully.
Hence i have configured the pi and it now works headlessly.
Tanga
Sat Feb 02, 2013 3:37 am
I'm in the same boat. I really need the initial password / login for Occidentalis so I can shell in.
Raspberry Pi (Raspbian) Tutorials by a fellow noob:
http://noobsquared.blogspot.com.au/
Mqrius
Wed Dec 04, 2013 3:42 pm
For other people stumbling across this thread by googling:
Username: pi
Password: raspberry
