PaulUK
Not able to install software on R-PI 4 running Buster
Tue Feb 04, 2020 5:44 pm
Hello All,
First post here, I'm having problems installing packages/software using "sudo apt install XXXX" from terminal and using the Add/Remove Programs app. For example I wanted to install GIMP with "sudo apt install gimp", here are the errors that I get after I enter "y" to continue.
Err:1 http://raspbian.raspberrypi.org/raspbian buster/main armhf ghostscript armhf 9.27~dfsg-2
  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/ghostscript/ghostscript_9.27~dfsg-2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I get similar messages when I try to install Octave, KiCad, FreeCAD and many others. Please can someone please help? I did not have these problems with the Rasberry Pi 2. Thank you.
6by9
Re: Not able to install software on R-PI 4 running Buster
Tue Feb 04, 2020 5:52 pm
"sudo apt update" first.
TheoPA3DSS
Mon Feb 10, 2020 10:11 am
I have serveral Pi's, one will not update and i don't know why:
pi@28:~ $ sudo apt update
Get:1 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Fetched 25.4 kB in 3s (6,808 B/s)
Reading package lists... Done
Building dependency tree
All packages are up to date.
pi@28:~ $ sudo apt full-upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@28:~ $ uname -a
Linux 28 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
pi@28:~ $ ./model.sh
Raspberry Pi 3 Model B Plus Rev 1.3
Revision        : a020d3
I have an old Pi from 2014 and no problems with the update:
Raspberry Pi Model B Rev 2
Revision        : 000e
No LSB modules are available.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:        10
Codename:       buster
Linux 200 4.19.97+ #1294 Thu Jan 30 13:10:54 GMT 2020 armv6l GNU/Linux
The Pi4 also no problems with the update.
davidcoton
Mon Feb 10, 2020 10:49 am
Your Pi3B+ appears to be still running Stretch. The update is reporting that there is nothing to upgrade, as might be expected for an old OS.
Nothing to worry about (except that your OS is outdated), but you might want to start over with Buster. Upgrade across versions is possible but not recommended.
TheoPA3DSS
Mon Feb 10, 2020 11:04 am
Ah, thank you for the fast clear answer David !!
