palAlv
RPi 4 not displaying on TV
Mon Feb 03, 2020 12:58 pm
I have a brand new Raspberry Pi 4 and I have installed Raspbian via NOOBS on it. When connecting to my PC monitor with HDMI everything works fine, but when I connect to my TV nothing is displayed. I have tried changing the values in config.txt as described here: https://www.raspberrypi.org/forums/view ... hp?t=34061. These are my current values:
hdmi_force_hotplug=1
config_hdmi_boost=4
hdmi_drive=2
I have also tried with several different HDMI cables, but to no avail. Any suggestions?
schyena
Re: RPi 4 not displaying on TV
Mon Feb 03, 2020 2:57 pm
Bump!
I'm having the exact same issue and it's getting really annoying how I have to boot to my monitor first then switching back to the TV.
FTrevorGowen
Mon Feb 03, 2020 3:00 pm
config_hdmi_boost=4
hdmi_drive=2
IIRC, the "boost" option has no effect on a P4B. What happens if you hold/toggle the Shift key when you switch on the Pi (ie.do you get to see the NOOBS installer's recovery screen?) Did you make sure that the T.V. was on and switched to the correct input?
Trev.
palAlv
Tue Feb 04, 2020 9:49 am
config_hdmi_boost=4
hdmi_drive=2
Trev.
Yes, I get to see the recovery screen. And yes, TV is on and on correct input.
