hansandreasr
RasPi only boots correct when HDMI is plugged in
Wed Jan 29, 2020 12:34 pm
It seems that this was an issue some time ago, since most posts about this issue are 5+ years old, but i am encountering now and the given solution to it back in the day don't work for me.
here is what is going on:
i want to let the pi run without a screen connected, but when i boot the pi nothing happens.
when i boot the pi connected to a screen via the hdmi port everything goes as normal,
i can disconnect the hdmi cable at that point and it keeps running as it should.
even the screen has not to be turned on and the pi will boot as it should!
but when there is nothing plugged in, nothing happens.
i'm using a raspberry pi 3B+ & rasbian buster (the version of june 2019)
aBUGSworstnightmare
Re: RasPi only boots correct when HDMI is plugged in
Wed Jan 29, 2020 1:02 pm
Add below to config.txt
  hdmi_force_hotplug
all details here https://www.raspberrypi.org/documentati ... t/video.md
hansandreasr
Wed Jan 29, 2020 2:40 pm
it is already in the config folder as
hdmi_force_hotplug = 1
hansandreasr
Wed Jan 29, 2020 8:03 pm
is it an idea to copy paste the full config.txt in here?
hansandreasr
Thu Jan 30, 2020 12:22 pm
any engineer that can help me out?
thank you in advance!
Burngate
Sun Feb 02, 2020 11:20 am
Is it
#hdmi_force_hotplug=1
or
Removing the # makes it live
Sun Feb 02, 2020 2:09 pm
Remove the spaces
hansandreasr
Wed Feb 05, 2020 8:14 pm
Is it
or
AHA!
this worked!
thx @Burngate !
and
does that mean that removing the "#" always makes the command live in the coinfig folder?
i thought i had to change that number "hdmi_force_hotplug=1" to "hdmi_force_hotplug=0"
to turn it off....
everything starts with the # so i thought that was just code or something...
hansandreasr
Wed Feb 05, 2020 8:16 pm
Remove the spaces
it was in the config without space, i just added them while typing it here...
my bad, but thanks anyway for the help @DougieLawson !
Burngate
Thu Feb 06, 2020 10:31 am
Yes - the "#" is just their way of marking something as a remark rather than code.
Other places, other methods - you're probably too young to remember BBC BASIC's "REM"
It's just assumed you already know this, like knowing which side of the plane the pilot sits on (helicopters tend to be opposite to fixed-wing planes, for no discernable reason)
