earthdog
PI4 Problems with Philips TV
Tue Jan 28, 2020 8:21 pm
PI4 with original power supply and original hdmi 1m cable.
Eliminated faulty cable and power supply by using second set of each.
Pi4 works perfectly fine when connected to my 2 DELL monitors.
I think the problem lies with my Philips TV. Model is 55PUS7304.
The problem started when i tried the weekly retropie build. I then moved on to test a fresh rasbian setup and the problem is the same.
The problem is :
https://drive.google.com/file/d/16a9w_o ... p=drivesdk
https://drive.google.com/file/d/16XZpci ... p=drivesdk
I then tried many combos from the video FAQ page an dnothing seemed to make it work.
Sometimes i get no TV message when i run "tvservice -s".
All enhanced modes off the TV HDMI ports are off.
Find below the output of tvservice -d edid.dat; /opt/vc/bin/edidparser edid.dat command:
Enabling fuzzy format match...
Parsing edid.dat...
HDMI:EDID version 1.3, 1 extensions, screen size 144x81 cm
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is Philips_FTV
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 48-62 Hz, horizontal is 15-70 kHz, max pixel clock is 300 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 60 Hz (16)
HDMI:EDID found CEA detail timing format: 1920x1080p @ 50 Hz (31)
HDMI:EDID established timing I/II bytes are 21 08 00
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
HDMI:EDID standard timings block x 8: 0xB300 9500 A940 9040 8100 8180 8140 0101
HDMI:EDID found DMT format: code 58, 1680x1050p @ 60 Hz (16:10) in standard timing 0
HDMI:EDID found DMT format: code 47, 1440x900p @ 60 Hz (16:10) in standard timing 1
HDMI:EDID found DMT format: code 51, 1600x1200p @ 60 Hz (4:3) in standard timing 2
HDMI:EDID found DMT format: code 42, 1400x1050p @ 60 Hz (4:3) in standard timing 3
HDMI:EDID found DMT format: code 28, 1280x800p @ 60 Hz (16:10) in standard timing 4
HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 5
HDMI:EDID found DMT format: code 32, 1280x960p @ 60 Hz (4:3) in standard timing 6
HDMI:EDID parsing v3 CEA extension 0
HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
HDMI:EDID found CEA detail timing format: 3840x2160p @ 30 Hz (95)
HDMI:EDID found CEA detail timing format: 1920x1080p @ 24 Hz (32)
HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz
HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
HDMI:EDID found CEA format: code 34, 1920x1080p @ 30Hz
HDMI:EDID found CEA format: code 33, 1920x1080p @ 25Hz
HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
HDMI:EDID found CEA format: code 93, 3840x2160p @ 24Hz
HDMI:EDID found CEA format: code 95, 3840x2160p @ 30Hz
HDMI:EDID found CEA format: code 94, 3840x2160p @ 25Hz
HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48|88|96 kHz, sample size: 16|20|24 bits
HDMI:EDID found audio format 6 channels AC3, sample rate: 32|44|48 kHz, bitrate: 640 kbps
HDMI:EDID found audio format 6 channels DTS, sample rate: 32|44|48 kHz, bitrate: 1536 kbps
HDMI:EDID found audio format 8 channels Dobly Digital+, sample rate: 44|48 kHz, codec define: 1
HDMI:EDID found audio format 6 channels DTS-HD, sample rate: 32|44|48|88|96 kHz, codec define: 1
HDMI:EDID found audio format 8 channels MLP, sample rate: 48 kHz, codec define: 3
HDMI:EDID found HDMI VSDB length 13
HDMI:EDID HDMI VSDB has physical address 3.0.0.0
HDMI:EDID HDMI VSDB supports AI:no, dual link DVI:no
HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:yes
HDMI:EDID HDMI VSDB max TMDS clock 300 MHz
HDMI:EDID HDMI VSDB does not support content type
HDMI:EDID HDMI VSDB supports extended resolutions 1,2,3
HDMI:EDID found Video Capability DB length 2
HDMI:EDID video capability: CE:1 IT:2 PT:0 QS:1
HDMI:EDID extended data block tag 0x05 length 3 not supported
HDMI:EDID extended data block tag YCbCr420VideoData - length 3
HDMI:EDID Disabling mode 97 as YUV420 only
HDMI:EDID Disabling mode 96 as YUV420 only
HDMI:EDID extended data block tag 0x06 length 3 not supported
HDMI:EDID filtering formats with pixel clock unlimited MHz or h. blanking unlimited
HDMI:EDID best score mode initialised to CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0)
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 61864)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 66472)
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 135592)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 18432
HDMI:EDID best score mode is now CEA (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz (score 149416)
HDMI:EDID CEA mode (6) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (7) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID DMT mode (9) 800x600p @ 60 Hz with pixel clock 40 MHz has a score of 28800
HDMI:EDID best score mode is now CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz (score 5398248)
HDMI:EDID DMT mode (16) 1024x768p @ 60 Hz with pixel clock 65 MHz has a score of 47185
HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID CEA mode (19) 1280x720p @ 50 Hz with pixel clock 74 MHz has a score of 117160
HDMI:EDID CEA mode (20) 1920x1080i @ 50 Hz with pixel clock 74 MHz has a score of 128680
HDMI:EDID CEA mode (21) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (22) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID DMT mode (28) 1280x800p @ 60 Hz with pixel clock 83 MHz has a score of 86440
HDMI:EDID CEA mode (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz has a score of 4732360
HDMI:EDID CEA mode (32) 1920x1080p @ 24 Hz with pixel clock 74 MHz has a score of 3624532
HDMI:EDID DMT mode (32) 1280x960p @ 60 Hz with pixel clock 108 MHz has a score of 98728
HDMI:EDID CEA mode (33) 1920x1080p @ 25 Hz with pixel clock 74 MHz has a score of 128680
HDMI:EDID CEA mode (34) 1920x1080p @ 30 Hz with pixel clock 74 MHz has a score of 149416
HDMI:EDID DMT mode (35) 1280x1024p @ 60 Hz with pixel clock 108 MHz has a score of 103643
HDMI:EDID DMT mode (42) 1400x1050p @ 60 Hz with pixel clock 121 MHz has a score of 113200
HDMI:EDID DMT mode (47) 1440x900p @ 60 Hz with pixel clock 106 MHz has a score of 102760
HDMI:EDID DMT mode (51) 1600x1200p @ 60 Hz with pixel clock 162 MHz has a score of 140200
HDMI:EDID DMT mode (58) 1680x1050p @ 60 Hz with pixel clock 146 MHz has a score of 130840
HDMI:EDID CEA mode (93) 3840x2160p @ 24 Hz with pixel clock 297 MHz has a score of 423130
HDMI:EDID CEA mode (94) 3840x2160p @ 25 Hz with pixel clock 297 MHz has a score of 439720
HDMI:EDID CEA mode (95) 3840x2160p @ 30 Hz with pixel clock 297 MHz has a score of 4522664
HDMI0:EDID preferred mode remained as CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz
HDMI:EDID has HDMI support and audio support
/opt/vc/bin/edidparser exited with code 0
earthdog
Re: PI4 Problems with Philips TV
Wed Jan 29, 2020 9:02 pm
So the problem was that the cable needed to be trimmed off some plastic since the case did not allow it to be put fully into the PI...
2 days lost :( But at least i ve learned a lot
