Pavel_47
Re: Cannot upgrade RPi4
Thu Jan 23, 2020 10:54 pm
You mean reflash SD and do all the steps I did before (e.g. make upgrade of about 600Mb) ?
Imperf3kt
Thu Jan 23, 2020 10:58 pm
Yes, as you cannot be sure what someone who might have accessed your Pi might have done. It is highly likely compromised.
reflashing from a clean install is the only way to be sure nothing that shouldn't be there, isn't.
botnets, crypto miners, viruses, keystroke loggers, just to name a few.
55:55:44:44:4C
52:4C:52:42:41
Pavel_47
Thu Jan 23, 2020 11:02 pm
Ok, thanks
Fri Jan 24, 2020 12:24 am
Pavel_47 wrote:
Thu Jan 23, 2020 6:33 pm
Just delete the offending key
How ?
The error message tells you the command you need to enter.
This is a doctor free zone.
gkreidl
Fri Jan 24, 2020 5:15 am
Don't create a panic!
If the OP is behind a router and port 22 has not been forwarded on it, nothing bad could have happened.
Minimal Kiosk Browser (kweb)
Pavel_47
Fri Jan 24, 2020 9:32 am
After reflashing, changing password and installing aptitude, upgrade works.
Thanks.
Fri Jan 24, 2020 9:39 am
Thanks.
Installing aptitude should not have been necessary. Updates and upgrade should be perfectly possible with apt.
“I own the world’s worst thesaurus. Not only is it awful, it’s awful."
Pavel_47
Fri Jan 24, 2020 9:59 am
But as I've mentioned at the beginning, upgrade didn't work using apt-get.
Then I was suggested to install aptitude.
And now I see that upgrade works.
Fri Jan 24, 2020 10:05 am
But it should work without aptitude. That's the point. And it does appear to work for everyone else.
ShiftPlusOne
Fri Jan 24, 2020 1:00 pm
It would've been possible with apt, but it wasn't entirely obvious what was wrong. It would take a lot of back and forth of "what does this command say?". Aptitude is a little smarter in figuring things out on its own and providing different options to resolve issues.
Botspot
Fri Jan 24, 2020 1:17 pm
+1 Exactly why I suggested it.
Ever wanted to run an .img file before flashing it to an SD card?
Or wished you could run Stretch on a Pi 4?
Or wanted to run two versions of Raspbian on a single Pi simultaneously?
You can do all of that, and more, with my Vdesktop script - http://bit.ly/VDESKTOP
Pavel_47
Fri Jan 24, 2020 2:31 pm
Probably it should, but in my particular case it didn't work. Here what I got before installing aptitude:
[email protected]:~ $ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
vlc-bin : Depends: libvlc-bin (= 3.0.8-0+deb10u1+rpt1) but 3.0.8-0+deb10u1+rpt7 is to be installed
vlc-plugin-skins2 : Depends: vlc-plugin-qt (= 3.0.8-0+deb10u1+rpt7) but 3.0.8-0+deb10u1+rpt1 is to be installed
E: Broken packages
Aptitude installing settled the issue.
Imperf3kt
Fri Jan 24, 2020 8:27 pm
I wasn't trying to. I've never heard that a router will save you from the dangers presented by enabling SSH without changing the default password.
55:55:44:44:4C
52:4C:52:42:41
gkreidl
Sat Jan 25, 2020 6:28 am
You shouldn't spread what you heard but what you understand.
Read about port forwarding and NAT (network address translation).
