haaldemir
Act green led does not appear
Thu Jan 23, 2020 1:46 pm
Hello
I buyed new Raspberry Pi 4 4 gb. I already have before pi 4 and pi 3b+. Their lights working well. I setup it, work good. booting and working correctly. Bu act led never appear on booting and working. I already contacted buying company waiting ansver them. Can i any test to light working? Or i buyed not working act led Pi 4?
pcmanbob
Re: Act led does not appear
Thu Jan 23, 2020 3:04 pm
I would guess the simplest test to check the green LED would be to unplug every thing from your pi , remove the SD card and then connect the power to it, the green LED should flash 4 times and break and repeat the 4 flashes and so on.
The red LED should be on all the time 5v is connected to the pi if you have a good 5V supply.
haaldemir
Thu Jan 23, 2020 3:24 pm
Thank You for your answer pcmambob. I tested no green light only red light . I am using official powersupply for pi 4. Green Led damaged i think from factory.
