Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
dc g++-4.9 gir1.2-atk-1.0 gir1.2-freedesktop gir1.2-gdkpixbuf-2.0 gir1.2-gmenu-3.0 gir1.2-gtk-3.0 gir1.2-pango-1.0 libalgorithm-c3-perl libarchive-extract-perl libasprintf0c2 libass5 libboost-filesystem1.55.0
libboost-program-options1.55.0 libboost-regex1.55.0 libcgi-fast-perl libcgi-pm-perl libchromaprint0 libclass-c3-perl libclass-c3-xs-perl libcloog-isl4 libcpan-meta-perl libdata-optlist-perl libdata-section-perl libdc1394-22 libdca0
libdirectfb-1.2-9 libdvdnav4 libdvdread4 libelfg0 libenca0 libfaad2 libfcgi-perl libflite1 libglew1.10 libgme0 libgnome-menu-3-0 libgtkglext1 libisl10 libjim0.75 libkate1 liblog-message-perl liblog-message-simple-perl libmimic0
libmjpegutils-2.1-0 libmms0 libmodplug1 libmodule-build-perl libmodule-pluggable-perl libmodule-signature-perl libmpeg2encpp-2.1-0 libmpg123-0 libmplex2-2.1-0 libmro-compat-perl libntdb1 libofa0 liborcus-0.8-0 libpackage-constants-perl
libparams-util-perl libpod-latex-perl libpod-readme-perl libpython3.4 libpython3.4-dev libpython3.4-minimal libpython3.4-stdlib libregexp-common-perl librtimulib-dev librtimulib-utils librtimulib7 libsoftware-license-perl libsoundtouch0
libspandsp2 libsrtp0 libstdc++-4.9-dev libsub-exporter-perl libsub-install-perl libswscale3 libterm-ui-perl libtext-soundex-perl libtext-template-perl libtimedate-perl libvo-aacenc0 libvo-amrwbenc0 libwildmidi-config libwildmidi1
libwps-0.3-3 libzbar0 lxkeymap pix-icons pix-plym-splash pixel-wallpaper python-cairo python-chardet python-colorama python-dbus-dev python-distlib python-gobject python-gobject-2 python-gtk2 python-html5lib python-ndg-httpsclient
python-pyasn1 python-requests python-rtimulib python-sense-hat python-support python-urllib3 python-xklavier python3-rtimulib python3.4 python3.4-dev python3.4-minimal
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
ifupdown init-system-helpers keyutils libfdisk1 libip4tc0 libjim0.76 libpam-systemd libseccomp2 libsystemd0 libudev1 nfs-common plymouth-themes systemd sysvinit-utils udev usb-modeswitch util-linux
Suggested packages:
ppp rdnssd open-iscsi watchdog systemd-ui systemd-container comgt wvdial util-linux-locales
keyutils libfdisk1 libip4tc0 libjim0.76 libseccomp2
The following packages will be upgraded:
ifupdown init-system-helpers libpam-systemd libsystemd0 libudev1 nfs-common plymouth plymouth-themes systemd sysvinit-utils udev usb-modeswitch util-linux
13 upgraded, 5 newly installed, 3 reinstalled, 0 to remove and 156 not upgraded.
Need to get 6,461 kB/8,858 kB of archives.
After this operation, 1,308 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Err:1
http://mirrordirector.raspbian.org/raspbian stretch/main armhf libfdisk1 armhf 2.29.2-1+deb9u1
Temporary failure resolving 'mirrordirector.raspbian.org'
Err:2
http://archive.raspberrypi.org/debian stretch/ui armhf plymouth armhf 0.9.2-4+rpi1
Temporary failure resolving 'archive.raspberrypi.org'
Err:3
http://mirrordirector.raspbian.org/raspbian stretch/main armhf init-system-helpers all 1.48
Err:4
http://archive.raspberrypi.org/debian stretch/ui armhf plymouth-themes armhf 0.9.2-4+rpi1
Err:5
http://mirrordirector.raspbian.org/raspbian stretch/main armhf util-linux armhf 2.29.2-1+deb9u1
Err:6
http://mirrordirector.raspbian.org/raspbian stretch/main armhf sysvinit-utils armhf 2.88dsf-59.9
Err:7
http://mirrordirector.raspbian.org/raspbian stretch/main armhf libip4tc0 armhf 1.6.0+snapshot20161117-6
Err:8
http://mirrordirector.raspbian.org/raspbian stretch/main armhf libseccomp2 armhf 2.3.1-2.1+deb9u1
25% [Working]
