Sun Jan 19, 2020 1:09 am
Windows does not understand Linux partitions and will produce a "billion popups" requesting you to reformat them regardless of whether you have resized them or not (always decline!).
I never tried resizing them myself, but if PINN freezes afterwards, then maybe gparted changed something it didn't like.
If partitions are referenced using PARTUUID, then make sure that gparted does not alter these, otherwise it will wait indefinitely for the correct partition to show up. In which case, you have some fixups to do.
If you can't get gparted to work, I suggest you start afresh using pinn.mjh.nz to specify the OS sizes you want. Backup your existing OSes first, if you want to keep what's on them. After re-installing, you can restore your backups into the correctly resized partitions. It's a bit more longwinded, but it will work.
