Fri Jan 17, 2020 5:08 pm
So possible errors with your circuit.
1. Feeding chip from 6v means you need 4.2V input to be seen as a high input ( pi gpio is 3.3V ).
2. There does not appear to be a ground from the pi connected to your bread board.
3. There does not appear to be a current limiting resistor in the LED circuit.
4. I am not even sure you can drive an LED from the output of a logic gate directly.
So why do you want to use the 7474HC08 as a driver for your LED ?
A red,green or yellow LED connected in series with a 470 ohm resistor , connected to your pi between a gpio pin set to output and ground will light up if the output is set to high.
if you specifically want to power your LEDs from 6v use a simple transistor/resistor driver circuit between the gpio pin and the LED.
