sandoz
rpi3 not booting with usb flash drive connected
Thu Jan 16, 2020 7:31 am
my rpi3 is not booting with a usb flash drive connected.
First i thought it was a faulty flashdrive, but after change it to another disk, i get the same problems (kernel panic)
I tried directly to the usb connectors on the pi, and through a powered hub, but no result.
What can be wrong?
HawaiianPi
Re: rpi3 not booting with usb flash drive connected
Thu Jan 16, 2020 8:36 am
Is the system booting from USB or SD card?
sandoz
Thu Jan 16, 2020 9:21 am
Booting from ssd, with boot partition on sd card
HawaiianPi
Thu Jan 16, 2020 11:09 am
Then it's probably the way you are specifying the root partition and mount points (using /dev/sdxx instead of UUID or PARTUUID).
What's in your /etc/fstab file, and what does the following command return.
ls -l /dev/disk/by-partuuid
sandoz
Thu Jan 16, 2020 11:28 am
No, I have disabled all mount points
For now when I reboot I manually have to mount.
I can only attach USB flash drive when the pi is booted, and then manually mount
When the USB drive is connected, the pi doesn't boot
sandoz
Thu Jan 16, 2020 11:54 am
this is the last part of the error. I cannot find it in the logs:
https://pasteboard.co/IQe5uWj.jpg
this is with a usb drive attached, without it no problems booting
proc            /proc           proc    defaults          0       0
PARTUUID=5576ee7f-ebf9-4773-9988-7f8694f8c974  /boot           vfat    defaults          0       2
PARTUUID=f36137b7-7837-4281-960f-9a5b41dc6e31  /               ext4    defaults,noatime  0       1
#5576ee7f-ebf9-4773-9988-7f8694f8c974
#f36137b7-7837-4281-960f-9a5b41dc6e31
#PARTUUID=5576ee7f-ebf9-4773-9988-7f8694f8c974  /boot           vfat    defaults          0       2
#PARTUUID=d700cc54-02  /               ext4    defaults,noatime  0       1
#/dev/disk/by-uuid/9ca404c3-68b3-4215-b3d6-4d28b3af6f7e /mnt/usb        ext4    rw,relatime   0    2
#/dev/sdb1   /mnt/usb        ext4    rw,relatime   0    2
#/dev/sda1       /mnt/usb        ext4    rw,relatime   0    2
#UUID=9ca404c3-68b3-4215-b3d6-4d28b3af6f7e       /mnt/usb     ext4    defaults,noatime,noauto  0     0
# a swapfile is not a swap partition, no line here
#   use  dphys-swapfile swap[on|off]  for that
#mount smb share
//192.168.1.111/rpi_backup      /mnt/usb                cifs    uid=0,credentials=/home/pi/.smb,iocharset=utf8,noperm 0 0
sandoz
Sat Jan 18, 2020 8:29 am
anyone? i have no idea
RonR
Sat Jan 18, 2020 8:31 pm
Running Raspbian from USB Devices : Made Easy
sandoz
Sat Jan 18, 2020 8:41 pm
Thank you, but that's not the problem
RonR
Sat Jan 18, 2020 9:59 pm
There's a good chance it is. Your fstab is incorrect and usb-boot will set it up correctly for you (as well as your SD card's cmdline.txt).
A UUID is not the same as a PARTUUID, but you're using a UUID as if it is:
should be
A PARTUUID is eight hex digits followed by a partition number, for example: 1a3b5c7d-02
If you'd like to use PARTUUID's (which is the more common practice), you can find a device's PARTUUID with the 'blkid' command.
HawaiianPi
Sun Jan 19, 2020 12:07 am
If that's really your /etc/fstab file, I'm surprised the system boots at all, with or without the extra USB drive.
Boot the system, connect the USB drive, and post the output of the blkid command.
RonR
Sun Jan 19, 2020 12:13 am
So was I. But I tried it, and the system actually boots: with a READONLY filesystem.
sandoz
Tue Jan 21, 2020 2:03 pm
its not readonly here
anyway, here are the asked infos:
[email protected]:~$ sudo blkid
/dev/mmcblk0p1: LABEL="boot" UUID="9304-D9FD" TYPE="vfat" PARTUUID="d700cc54-01"
/dev/mmcblk0p2: LABEL="rootfs" UUID="29075e46-f0d4-44e2-a9e7-55ac02d6e6cc" TYPE="ext4" PARTUUID="d700cc54-02"
/dev/sda1: LABEL="boot" UUID="9304-D9FD" TYPE="vfat" PARTLABEL="Microsoft basic data" PARTUUID="5576ee7f-ebf9-4773-9988-7f8694f8c974"
/dev/sda2: LABEL="rootfs" UUID="640f56d4-2a40-419e-a8e8-5f83dacbd444" TYPE="ext4" PARTLABEL="Linux filesystem" PARTUUID="f36137b7-7837-4281-960f-9a5b41dc6e31"
/dev/mmcblk0: PTUUID="d700cc54" PTTYPE="dos"
/dev/sdb1: UUID="9ca404c3-68b3-4215-b3d6-4d28b3af6f7e" TYPE="ext4" PARTUUID="46d90c2e-01"
cmdline.txt
dwc_otg.lpm_enable=0 console=tty1 console=serial0,115200 root=/dev/sda2 rootfstype=ext4 elevato$
i could not get the pi to boot from the ssd, with the sd card not inserted. Thats why i have the boot on sd, and the root on the ssd
i rsynced the sd to the ssd, then edited cmdline.txt, and its running ok now, except when i insert an extra usb dongle.
i see some strange thing: the sdcard and sda1 have the same UUID?
RonR
Tue Jan 21, 2020 6:32 pm
That's because you have 'root=/dev/sda2' in cmdline.txt. When you insert another USB device, the new device is becoming /dev/sda and your SSD is becoming /dev/sdb.
That's due to a flaw that was introduced in Raspbian Buster (devices no longer get a unique PARTUUID and UUID). It's left up to you to resolve this conflict.
usb-boot will correct all these issues for you, resulting in a system that boots reliably to the desired device regardless of whether you insert additional devices.
