ASCII8BiT
RPI4 Back Solder Pads
Mon Jan 13, 2020 7:15 pm
How do I supply energy from the back pads? Which one is for what? Where i can find that diagram?
klricks
Re: RPI4 Back Solder Pads
Mon Jan 13, 2020 7:37 pm
https://www.raspberrypi.org/documentati ... educed.pdf
ASCII8BiT
Sat Jan 25, 2020 12:31 pm
I may be wrong but TP1, TP2, TP3 for VCC (Power) ; TP7, TP8 TP9 and TP12 Ground Pads. Am i right?
hippy
Sat Jan 25, 2020 7:31 pm
Looks correct according to the schematic I have.
You can use a multi-meter to do a continuity check on a completely disconnected Pi, between the pads and GPIO header pins, to check they are and to ensure you have located the correct pads.
It's always worth doing that double-check.
drgeoff
Sat Jan 25, 2020 7:50 pm
If you are going to solder to the underside of the board I suggest soldering to the existing solder joints of the relevant pins of the GPIO header rather than the TPs.
LTolledo
Sat Jan 25, 2020 9:27 pm
On my RPi4B-2G NAS I supplied power via TP1 (5v) and TP7 (Gnd), using AWG20 wire
Some people be like:
